Hi,
First time poster
I have had issues playing Dolby Vision on my LG G2 TV via Fire TV Cube (3rd Gen). Plex app via Fire Cube works for some, same with stock Kodi.
I have since installed the Kodinerds version (build says 21.0-ALPHA1) and performance is better as a couple more files play in Dolby Vision.
However, some still do not play in DV, reverting to standard HDR. Thought this could be an issue with the Fire Cube, but after checking Media Info of the files that do and don't work, I don't see any difference as they all show:
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Any tips/recommendations to try and get these files to play in DV? Should I have installed a specific Kodinerds build for my Fire Cube? I am a complete novice so do go easy
Thank you.
