Shield Experience Upgrade 9.0.0 - 9.1.2
  • Ich habe auch schon mal ein kleines Bild oben links gehabt. So wie bei der Bild in Bild Funktion vom Fernseher. Habe das erst wieder weg bekommen als ich diesen refresh rate button im Menü gedrückt habe. Hatte ich auch noch nie gehabt.
    greetz, FoLeY ...
  • 9.0.1 wurde gerade freigegeben. Ich ergänze später den Startpost.
    Hier kann man sich nun fürs Hotfix 9.0.1+ anmelden.
    Anbei noch die Known Issues:
    These are the known and reported issues in SE9.0.1 that are being worked on. This is not the exhaustive list but rather the more common issues list. One off bugs, single user issues are not listed in here.
    • Wifi disconnects on a subset mesh/band steering network setups with wifi roaming enabled (Work around for now is to disable roaming in wifi settings)
    • While using external hard drives with NTFS format which do continuous reading/writing (DVR type applications), the drive stops working and SHIELD hangs and needs to be rebooted. This may also apply to exfat as both file systems are served by Paraon but likely does not apply to fat32 which has built in kernel support.
    • File transfer performance issue
    • Streaming Emby with https video stalls unless http2 is disabled
    • The drive speed test when adopting a storage drive always reports drive too slow
    • When Kodi is running in the background, refresh rate changes on apps in the foreground somtimes
    • Button mapper remap on Netflix button triggers Netflix button and the new button mapped
    • Popping audio when playing back over BT headphones while Dolby Processing is enabled. For now, disable Dolby Processing while playing back on headphone
    • Free space reports incorrect using SMB server feature in SHIELD
    • Adopted storage starts migrating but doesn't always complete
    • Twitch scaling/zooming/cropping behavior doesn't look correct
    • AI upscaling does not work when streaming GeForce NOW 1080p HDR content
    • Resolution is capped at 1080p when using ADB for screen capture
    • Unable to [definition='1','0']log[/definition] into Google or Netflix accounts when using restricted profile
    • Audio stutter issues with aptX-HD compatible headsets
    • VUDU does not cast in UHD
    • XBOX controllers may not automatically reconnect after disconnecting on SHIELD sleep
    • Change in mapping (Sterteched vs black bars) of 16:9 content to 16:10 display behavior from 8.2.3
    • When refresh rate switcher is enabled with the network [definition=12,2]debugging[/definition] feature popups asking for device authorization to the network debugger appear randomly
  • Quelle: https://www.nvidia.com/en-us/geforce/…released-21522/
    Habe auch gerade das Update vollzogen...mal schauen was da jetzt geht.
  • Sehe es auch gerade, bin auf RTL+ gespannt. Will Donnerstag Fußball sehen :)
  • Zitat von Nvidia
    Schild@NVIDIA 41m
    Es ist HotfFix 3 + ein paar Änderungen:
    1. behebt die WLAN-Roaming-Einstellung, sodass die Deaktivierung funktioniert.
    2. macht einen Mausklick-Fix rückgängig, der einige Aps zurückführte, um in den Tablet-Modus zu wechseln.
    3. hebt CEC-Fix auf, bei dem zurückgegangene Benutzer mit Schild wach bleiben, wenn Eingaben weggeschaltet werden.
    4. noch ein paar Kleinigkeiten.
  • Wieso downloaded die shield sich denn das Update automatisch ? Das war doch sonst nicht so. Es zu installieren hat sie sich aber nicht getraut. Auto update ist jedenfalls aus.
    Wo legt die denn das heruntergeladene hin ?
    Ist es bei einem reboot noch da ?
    Ich will das gerne loswerden , weil in den Entwickler Optionen das nicht auf full provided update stand. Hatte ich nach dem Werksreset vergessen wieder umzustellen.
    greetz, FoLeY ...
  • Kurzes Off Topic.
    Kann jemand mal Checken ob bei Ihm bei Disney+
    Walking Dead Staffel 11 , 3 von 8 Folgen laufen bei mir in Stereo, ob das bei euch so ist ?
    Danke
    PS. Hab gerade mal auf PC gegen gecheckt
    Folge 2,5 und 7 Laufen auf PC in 7.1 die restlichen Folgen in 5.1. Und genau diese 3 Folgen Laufen auf der Shield nur in Stereo
    PPS. Weiteres Beispiel 1 Staffel Desperates Housewives laufen alle nur in Stereo bei mir, in der Windows App in 7.1
    Staffel 2 zb. Läuft auf der Shield in 5.1 und auf dem PC auch in 5.1
    Solangsam habe ich das gefühl es liegt an dem 7.1 k.a was da "angeblich" nicht unterstützt wird
