Hey,
vielleicht kann mir jemand von euch evtl Helfen. Ich habe Probleme mit dem rmote mount Pugin.
Wollte meinen alten NAS Server in OMV mounen um alle Daten rüber zu schieben. Leider bekomme ich, egal mit welchen Dienst ich mich verbinden will, Fehlermeldungen aus dennen ich nicht schlau werde.
ailed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; mount '/srv/2d258cac-4dc2-4289-b87b-ae6ff5e3beae' 2>&1' with exit code '1': /sbin/mount.davfs: Mounting failed. 502 Bad Gateway
Fehler #0:
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color fstab 2>&1' with exit code '1': debian:
Function: file.accumulated
Result: True
Comment: Accumulator create_filesystem_mountpoint_d26f9643-0f94-4d8b-85f7-3902e25f3932 for file /etc/fstab was charged by text
Started: 20:24:19.307819
Duration: 0.846 ms
Changes:
Function: mount.mounted
Result: True
Comment: Target was already mounted
Started: 20:24:19.309376
Duration: 51.039 ms
Changes:
umount:
Forced remount because options (user_xattr) changed
Result: True
Comment: Accumulator create_bind_mountpoint_3b1f284b-9faf-47ce-9866-f9cb46ce0a82 for file /etc/fstab was charged by text
Started: 20:24:19.360664
Duration: 1.182 ms
Changes:
Result: True
Started: 20:24:19.361971
Duration: 10.294 ms
Changes:
Result: True
Comment: Accumulator create_remotemount_mountpoint_2d258cac-4dc2-4289-b87b-ae6ff5e3beae for file /etc/fstab was charged by text
Started: 20:24:19.372478
Duration: 1.094 ms
Changes:
Result: True
Comment: /srv/2d258cac-4dc2-4289-b87b-ae6ff5e3beae not mounted
Started: 20:24:19.373694
Duration: 10.666 ms
Changes:
Result: True
Comment: Accumulator create_remotemount_mountpoint_2fae77ab-1c83-437e-98ee-0a1e366a76c0 for file /etc/fstab was charged by text
Started: 20:24:19.384642
Duration: 1.234 ms
Changes:
Result: False
Comment: mount error(13): Permission denied
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Started: 20:24:19.386008
Duration: 2078.196 ms
Changes:
Function: file.blockreplace
Result: True
Comment: Changes were made
Started: 20:24:21.468188
Duration: 13.443 ms
Changes:
diff:
@@ -15,4 +15,5 @@
/dev/disk/by-uuid/c20a2df1-ddb3-44a5-afe1-7d08461a2406 /srv/dev-disk-by-uuid-c20a2df1-ddb3-44a5-afe1-7d08461a2406 ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl 0 2
/srv/dev-disk-by-uuid-c20a2df1-ddb3-44a5-afe1-7d08461a2406/ /export/OMV-Platte1 none bind,nofail 0 0
192.168.178.128 /srv/2d258cac-4dc2-4289-b87b-ae6ff5e3beae davfs _netdev,defaults,nofail,file_mode=777,dir_mode=777 0 0
+//Homeserver//Multimedia /srv/2fae77ab-1c83-437e-98ee-0a1e366a76c0 cifs _netdev,iocharset=utf8,vers=2.0,nofail,credentials=/root/.cifscredentials-02416223-c33a-4972-86a4-5ce704dd8953 0 0
# <<< [openmediavault]
Summary for debian
Succeeded: 8 (changed=2)
Failed: 1
Total states run: 9
Total run time: 2.168 s in /usr/share/php/openmediavault/system/process.inc:196
Stack trace:
#0 /usr/share/php/openmediavault/engine/module/serviceabstract.inc(62): OMV\System\Process->execute()
#1 /usr/share/openmediavault/engined/rpc/config.inc(167): OMV\Engine\Module\ServiceAbstract->deploy()
#2 [internal function]: Engined\Rpc\Config->applyChanges(Array, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod('applyChanges', Array, Array)
#5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(588): OMV\Rpc\ServiceAbstract->OMV\Rpc\{closure}('/tmp/bgstatusIS...', '/tmp/bgoutputhl...')
#6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(159): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#7 /usr/share/openmediavault/engined/rpc/config.inc(189): OMV\Rpc\ServiceAbstract->callMethodBg('applyChanges', Array, Array)
#8 [internal function]: Engined\Rpc\Config->applyChangesBg(Array, Array)
#9 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#10 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('applyChangesBg', Array, Array)
#11 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Config', 'applyChangesBg', Array, Array, 1)
#12 {main}
Alles anzeigen
Irgendwie werde ich da nicht schlau raus, bzw finde ich keinen Lösungsansatz.
Evtl hat jemnad vn euch ne idee.
LG
