Gab vor 12 Std. das Update auf 6.9.1:
Changelog:
Unraid OS 6.9.1
Bug fixes and minor improvements.
Notable Bug Fixes and Improvements
Fixed issue where code outside the Unraid OS Management Utility calling smartctl would set up conditions where devices would never spin down. Note: you still need @doron's SAS Spindown plugin to properly support SAS device spindown.
For Docker: if an in-tree GPU driver is loaded which results in creating /dev/dri/* device nodes, we set permissions for these nodes to 0777 in order to ease integration of containers using GPU for transcoding.
Typing 'exit' in a Terminal window will now close the window (yay!).
We added a 'no-cache' header to NoVNC web access so that future Unraid OS releases will no longer have stale web components.
Updated the openssl package to version 1.1.1j which has security updates.
Updated the Linux kernel to 5.10.21, a patch release to 5.10 LTS kernel.
Included kernel config settings necessary to include certain hardware monitoring devices and added support for new devices.
Driver Updates
The Nvidia GPU driver has been updated to 460.56 and should work with this kernel 5.10.21. Please install @ich777's Nvida-Driver plugin to download and install this driver.
Change Log
### Version 6.9.1 2021-03-08
Base distro:
- openssl: version 1.1.1j (CVE-2021-23841 CVE-2021-23840)
- openssl-solibs: version 1.1.1j
- ttyd: version 1.6.3
Linux kernel:
- version 5.10.21
- CONFIG_WATCHDOG: Watchdog Timer Support
- added several new hwmon drivers
Management:
- emhttp: monitor partition statistics instead of device statistics in spindown/spinup logic
- rc.local: ensure required directories exist on USB flash boot device
- rc.local: for Docker containers: grant access to graphics device nodes /dev/dri/*
- rc.nginx: add Cache-Control:nocache header to novnc
- webgui: Increase syslog buffer from 1000 to 3000 lines
- webgui: SysDevs fix display aberration
- webgui: Diagnostics: include modprobe.d files
- webgui: Diagnostics: include go as go.txt
- webgui: Update share security helptext
- webgui: Deprecate donation links in templates in lieu of links in CA profiles
- webgui: Protect GUI from invalid .page files
- webgui: Suppress ipv6 multicast entries in route table display
- webgui: synchronize helptext.txt with lang-en_US repo
- webgui: user management - disable password autocomplete
- webgui: Dashboard: Fix color for utilization of disks
