Nach Youtube Update (6.6.0) "alles weg" keine Anmeldung mehr zum Konto...
  • Ups total vergessen Rückmeldung zu geben, bei mir klappts jetzt auch wieder..
    TC
    Media-Server: Emby 4.x.x.x
    Clients:
    1x NUC W10 Kodi 19.x
    1x FireRV Stick 4K
  • Jup das normale YT Addon geht nicht.
    2021-06-16 15:55:14.152 T:2872 INFO <general>: [plugin.video.youtube] Running: YouTube (6.8.11+matrix.1) on Matrix (Kodi-19.1) with Python 3.8.5
    Path: /special/new_uploaded_videos_tv/
    Params: {}
    2021-06-16 15:55:14.336 T:6212 INFO <general>: CPythonInvoker(135, C:\Users\stefan\AppData\Roaming\Kodi\addons\script.embuary.helper\plugin.py): script successfully run
    2021-06-16 15:55:14.730 T:6212 INFO <general>: Python interpreter stopped
    2021-06-16 15:55:15.634 T:2872 INFO <general>: CPythonInvoker(127, C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\default.py): script successfully run
    2021-06-16 15:55:15.923 T:2872 INFO <general>: Python interpreter stopped
    2021-06-16 15:55:22.654 T:1728 INFO <general>: initializing python engine.
    2021-06-16 15:55:24.584 T:1728 INFO <general>: [plugin.video.youtube] Running: YouTube (6.8.11+matrix.1) on Matrix (Kodi-19.1) with Python 3.8.5
    Path: /play/
    Params: {'video_id': '_98Klf0y6Eo'}
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: Traceback (most recent call last):
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\yt_play.py", line 50, in play_video
    video_streams = client.get_video_streams(context, video_id)
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\client\youtube.py", line 104, in get_video_streams
    video_streams = video_info.load_stream_infos(video_id)
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\video_info.py", line 515, in load_stream_infos
    return self._method_get_video_info(video_id)
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\video_info.py", line 1032, in _method_get_video_info
    raise YouTubeException('No streams found')
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: youtube_plugin.youtube.youtube_exceptions.YouTubeException: No streams found
    2021-06-16 15:55:25.319 T:1728 ERROR <general>: [plugin.video.youtube] None
    2021-06-16 15:55:25.319 T:1728 INFO <general>: CPythonInvoker(136, C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\default.py): script successfully run
    2021-06-16 15:55:25.327 T:4268 ERROR <general>: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=_98Klf0y6Eo]
    2021-06-16 15:55:29.636 T:1728 INFO <general>: initializing python engine.
    2021-06-16 15:55:29.637 T:1728 INFO <general>: [plugin.video.youtube] Running: YouTube (6.8.11+matrix.1) on Matrix (Kodi-19.1) with Python 3.8.5
    Path: /play/
    Params: {'video_id': 'WJHBXk1K6W0'}
    2021-06-16 15:55:30.434 T:1728 ERROR <general>: Traceback (most recent call last):
    2021-06-16 15:55:30.434 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\yt_play.py", line 50, in play_video
    2021-06-16 15:55:30.435 T:1728 ERROR <general>:
    2021-06-16 15:55:30.435 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\client\youtube.py", line 104, in get_video_streams
    2021-06-16 15:55:30.435 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\video_info.py", line 515, in load_stream_infos
    2021-06-16 15:55:30.435 T:1728 ERROR <general>: File "C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\youtube_plugin\youtube\helper\video_info.py", line 1032, in _method_get_video_info
    2021-06-16 15:55:30.435 T:1728 ERROR <general>: youtube_plugin.youtube.youtube_exceptions.YouTubeException: No streams found
    2021-06-16 15:55:30.435 T:1728 ERROR <general>: [plugin.video.youtube] None
    2021-06-16 15:55:30.435 T:1728 INFO <general>: CPythonInvoker(136, C:\Users\stefan\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\default.py): script successfully run
    2021-06-16 15:55:30.446 T:4268 ERROR <general>: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=WJHBXk1K6W0]
  • Ack, kann ich für mich so bestätigen, hat letzte Nacht irgendwann um 2 Uhr die Arbeit eingestellt. Einlesen der Videoliste der abonnierten Kanäle funktioniert noch, aber jeder Abspielversuch scheitert.
  • Jupp Kodi Repo aktualisieren dann ist das Update verfügbar..
    TC
    Clients:
    1x FireRV Stick 4K
  • Lustigerweise ist die Versionsnummer dieselbe geblieben, das hatte mich anfangs von einem Update abgehalten. Aber ja, damit läuft es nun auch hier wieder, sehr schön. :)
    Zumindest teilweise. Es lassen sich einige Videos abspielen, andere aber noch immer nicht. MPEG-Dash- Einstellungen sind hierbei egal, bzw. das ändert nichts.
    Einmal editiert, zuletzt von Kiezkickerde (17. Juni 2021 um 00:23) aus folgendem Grund: Einschränkung auf einige Videos.
  • Ich hoffe es ist ok wenn ich die Frage hier stelle, möchte ungerne einen neuen Thread aufmachen:D
    Wenn ich 4k Videos suche, funktionieren die alle perfekt, TV schaltet schön auf 4k und Bild sieht auch super aus aber wenn ich ein Video vom "Blocktrainer" schauen will, sieht es so aus wie im Anhang. Kann das jemand mal gegen testen? Hab schon alle Einstellungen ausprobiert :( danke!
  • Für euch wahrscheinlich eine dumme Frage: Wo finde ich das aktuelle Kodi Repo? Ich habe hier das Kodinerds Repo gefunden aber das ist nicht kürzlich aktualisiert.
    Habe es hinbekommen. Habe im Addon-Manager irgendwo Updates gemacht. Hat aber nichts gebracht. Dann irgendwann doch neu gebootet und dann bot er doch ein Update auf 6.8.14 an.
    Super geht wieder.
    Dank an die, die das immer alles flicken und machen!!
  • Bei mir läuft leider seit der YouTube Version 6.8.14. Betriebssystem libreelec Version 9.2.7 nichts mehr. Nur die Fehlermeldung stream Not found. Scheint anscheinend ein geographisches Problem zu sein. Mit nem amerikanischen VPN funzt alles wunderbar. Hoffe das kriegen die gefixt.
    Nachtrag:
    Gibt jetzt ein Update 6.8.15 von anxdpanic normal wie immer in der repo enthalten als Update. Jetzt funzt bei mir alles wieder wunderbar.
