Fernbedienung Imon Pad Wiederholrate zu hoch
    bei der Bedienung über das Steuerkreuz mit der Soundgraph Imon Pad rast die Markierung nur so durchs Menü.
    3x drücken der Hoch-Taste (2x länger + 1x kurz) auf der Fernbedienung brachte folgende Logeinträge:
    2019-11-24 08:14:24.070 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.099 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.136 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.139 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.203 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.219 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.270 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.299 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.336 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.339 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.419 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.439 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:24.589 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:24.599 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:26.359 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:26.379 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:26.419 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:26.439 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:26.486 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:26.499 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:28.663 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:28.680 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:28.749 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:28.759 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    2019-11-24 08:14:28.813 T:2933912432 DEBUG: LIRC: - NEW 67 0 KEY_UP devinput (KEY_UP)
    2019-11-24 08:14:28.819 T:3011440656 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
    Ich habe bereits in der [definition='2','1']advancedsettings[/definition].xml folgendes eingefügt:
    <remotedelay>20</remotedelay>
    Laut Kodi-Wiki ist <remoterepeat> - Removed
    Wie/wo kann ich einstellen, dass eine Fernbedienungseingabevon Kodi nur alle x Millisekunden verarbeitet wird?
  • Laut Wiki:
    2.10.1 remotedelay
    The repeat delay for a LIRC remote control. A delay value between 1 and 20 before a remote button starts repeating on a long keypress (i.e. continuously sending button pushes while it's held down).
    Also ist ja bei 20 Schluss, oder?!
  • Siehe
    LibreELEC 9.0 uses in-kernel decoding with ir-keytable configurationas the main method to support infrared remotes on all platforms.
    Lirc is still available but the old lirc-only kernel drivers lirc_rpi andlirc_xbox have been removed and LibreELEC no longer ships with defaultlircd.conf files.
    The option to enable / disable Lirc in LibreELEC settings has been removedas well, lircd will now be started automatically if the/storage/.config/lircd.conf file is present.
  • Ja, eine Tastatur hängt dran.
    Die Fernbedienung inkl. Empfang und Verarbeitung funzt ja bis auf die Wiederholfrequenz perfekt.
    Es kann doch nicht sein, dass das die einzige Fernbedienung ist, die so eine hohe Wiederholfrequenz beim Tastendruck hat.
    Und KODI damit nicht vernünftig umgehen kann.
  • Probier den Tip von Don doch einfach mal aus, hatte das mit meinem LE Rechner und einer Harmony auch mal
    und meine mich zu erinnern, dass das Deaktivieren von LIRC die Lösung des Problems war.
    Versuch macht kluch :D und kost a nix.
  • dass das Deaktivieren von LIRC die Lösung des Problems war.
    Jetzt bin ich noch mehr verwirrt:Don sagt, dass ich kein LIRC aktiviert habe.
    Und Du sagtst ich soll es deaktivieren...
    Ich muss dazu sagen: Ich habe kaum einen Plan von Linux, so dass ich mir alles mit diversen Howtos zusammengebastelt habe.
    Also wenn mir einer sagt, was ich genau mal testen sollte, dann ist das kein Problem.
  • Oben steht es doch. Lirc ist nur dann aktiviert, wenn die Datei /storage/.config/lircd.conf existiert. Das ist offensichtlich nicht der Fall, Wobei ich das noch in Frage stellen würde, wenn da über WinSCP auf den RPi gegangen wurde. ",config" ist ein versteckter Ordner und da muss man wenigstens in WinSCP (oder was auch immer da benutzt wurde) das Anzeigen von versteckten Dateien aktivieren.
    Wie auch immer. Wenn diese Datei nicht existiert, dann ist Lirc auch nicht aktiv.
    Weiter haben wir ein ziemlich ausführliches Wiki dafür:
    https://wiki.libreelec.tv/infrared_remotes
    Wir bräuchten auch bitte mal einen SSH Zugang zu dem RPi und dann die Ausgabe von: ir-keytable
    Über das Kommando "ir-keaytable" kann man auch entsprechend ein delay und eine Repeat-Periode setzen. Dennoch würde ich gern erstmal die Ausgabe des Kommandos sehen,
