Hallo zusammen,
Nov 15 18:33:45 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:33:47 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Nov 15 18:34:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:34:10 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:34:12 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Nov 15 18:35:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:36:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:36:16 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:36:19 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Nov 15 18:36:19 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:36:22 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Nov 15 18:37:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:37:35 MyServer nginx: 2019/11/15 18:37:35 [error] 18118#18118: *3998956 upstream prematurely closed connection while reading response header from upstream, client: 192.168.0.120, server: , request: "GET /webterminal/ HTTP/1.1", upstream: "http://unix:/var/run/ttyd.sock:/", host: "192.168.0.2", referrer: "http://192.168.0.2/Dashboard"
Nov 15 18:37:44 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:37:47 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Nov 15 18:38:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:39:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:40:04 MyServer s3_sleep: Disk activity on going: sdd
Nov 15 18:40:07 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Down
Nov 15 18:40:10 MyServer kernel: r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Alles anzeigen
Sowas steht im syslog wenn der Fehler auftritt.
Macht sich bemerkbar, dass kurz das livetv in kodi Stock, oder Aufnahmen abspielen abbricht.
jemand Rat?
Seit 86 Tagen läuft mein Server jetzt ohne Probleme.
Vor einer Woche habe ich alle docker aktualisiert, und seit 3 Tagen dann diese Phänomen.
mehr Logs?
Irgendwelche andren Infos benötigt?
neustarten ist schwer, habe noch keine Lizenz gekauft... *pfeiff*
Ggf. Sollte ich das doch mal machen und mal Neustarten...
Aber evtl. Weiß ja jmd rat?
Grüße
Ich
