Shield TV 2019 Firmware Update und Hotfixe
  • Hier nun das neue HotFix Image für die Shield/Pro 2019.
    https://www.nvidia.com/en-us/geforce/…0-hotfix-image/
    The first HotFix image for the 2019 SHIELD TVs has been deployed on 11/6/2019 as version 32.7.301.38 and is based on the public 8.1 image with the follow fixes:
    First HotFix (32.7.301.38):
    - Match Content Color Space feature not working
    - Dolby ATMOs audio stickiness. ie. Play an ATMOS title and the next title the receiver stays in ATMOS mode
    - SONY BRAVIA KD55A8F can't set Dolby Vision mode at 59.95Hz
    - Corner cases of no Audio in Movies Anywhere, Vudu
    Note that there is still an issue with the color switch while in DV mode on Sony xbr55x900f that is being worked on for a future HotFix image.
  • Besser wäre es wenn der Thread zB Shield TV 2019 Firmware Update heißt.
    Gaming-PC: AMD 5600X | Nvidia 3060 Ti FE | MSI X570 Unify | Crucial Ballistix 32 GB 3600/16 | Corsair RMx 850w | Fractal Meshify 2 Compact |
    Internet: Magenta | Fritz!Box 6660 Cable | 1028 Mbit/s / 53 Mbit/s |
    Handy: Google Pixel 6 | Magenta 5G | Yesss |
  • Top, hat denn Vorteil das man über jedes Update reden kann und nicht nur dieses eine.
    Bei meinen Sony XE93 funktioniert DV dennoch nicht richtig. Farben sind falsch, im Nvidia Forum berichten andere Sony User das selbe.
  • Ein Nachteil könnten diese Hotfixe auch haben.
    Zitat von Nvidia
    Caveats of the HotFix process:
    1. There is no way to roll back from the HotFix or anyway for that matter without following the rooting/developer images process.
    2. There is no way to leave the HotFix process once you join it.
    3. HotFix images are not fully certified. The next official release will have all certifications. The only negative side affect we've noticed from this so far is that HD Homerun DRM channels will not work with the HotFix image so if that feature is important to you, please avoid the HotFix image.
    Übersetzt mit Google:
    Vorbehalte des HotFix-Prozesses:
    1. Es gibt keine Möglichkeit, ein Rollback vom HotFix oder von irgendetwas anderem durchzuführen, ohne den Rooting- / Developer-Images-Prozess zu befolgen.
    2. Sie können den HotFix-Prozess nach dem Beitritt nicht mehr verlassen.
    3. HotFix-Images sind nicht vollständig zertifiziert. Die nächste offizielle Veröffentlichung wird alle Zertifizierungen haben. Der einzige negative Nebeneffekt, den wir bisher bemerkt haben, ist, dass HD Homerun DRM-Kanäle nicht mit dem HotFix-Image funktionieren. Wenn diese Funktion für Sie wichtig ist, meiden Sie das HotFix-Image.
    worauf könnte sich das auswirken?
    Philips 77" Oled 806, Arcam AVR 31, VU Solo4K, Oppo UDP 203, Play Station 5, Nvidia Shield 2019, B&W 704 S3, B&W HTM71 S3, B&W 707 S3 ,SVS SB 2000 Pro, BlueSound Flex 2i, BlueSound Pulse 2, Synology DS 718+
  • Ich hab mich dennoch angemeldet weil ich gerne teste und zurück geht ja dennoch wenn auch mit etwas Aufwand.
  • Update auch drauf, sogar schon 2 für die FB, aktuell 1.07!
  • gibt es mit dem Hotfix Probleme mit Sky Go?
    Gerade mal installiert, es läuft ohne Probleme hier!
  • Gab mittlerweile den dritten HotFix für die Shield 2019.
  • Alexa funktioniert nun aber nicht wirklich gut. Ein und Ausschalten läuft perfekt, das starten von Apps aber nicht. YouTube kann ich starten, Netflix, Prime Video, Kodi usw starten aber nicht.
    Läuft DV denn jetzt mit dem letzten Patch ordentlich oder sind die Farben immer noch fehlerhaft?
  • Läuft DV denn jetzt mit dem letzten Patch ordentlich oder sind die Farben immer noch fehlerhaft?
    Zumindest mit Netflix ja.
