Nvidia Shield TV 2019 ( Erfahrungen, Einstellungen, ... )
  • hotfix 3 wurde heute abend released
    Third HotFix (32.7.301.64)
    - Resolves issues detecting Dolby Vision on some Sony, Vizio, and Phillips TVs
    - Fixes crash issues when accessory update notification is seen
    - Resolves cast playback issues when switching between HDR and SDR content
    - Adds message informing user AI upsclaing not available on rooted/unlocked devices
    - Fixes bug where IR control setup would fail on Samsung AVR/soundbars
    - Channels DVR app can now store recorded content over NAS
    - Resolves issue where passthrough was not available over USB DAC on 3rd party apps like KODI
    - SHIELD Alexa Skill now available in UK, IT, FR, ES, DE
    - Adds support for XBOX Elite 2 controller
    - Adds support for Sanscrit USB DAC
    - Fixes bug when manually setting "Audio fomats" would not be applied
    - Adds Atmos details to settings - device preferences - about - status - HDMI - audio mode
    - Add the ability to directly turn off Fixed Volume which will disable dolby processing
    - Resolve IR volume control issues when accesbility features enabled
    - Resolve issues when using and external dac and external microphone on separate devices
    - Add ability for Google Assitant to adjust volume on systems with an always connected/always on 2019 SHIELD remote pointing at the IR receiver.
    - Resolves issue preventing SHIELD controller 2015 firmware from updating.
    - Resolves issue causing 2019 SHIELD Remote IR transmitter time stuck on and train batteries prematurely.
  • Gibt es da auch wieder einen Link, um sich dafür einzutragen?
  • Gerade bekommen auch.
    Gaming-PC: AMD 5600X | Nvidia 3060 Ti FE | MSI X570 Unify | Crucial Ballistix 32 GB 3600/16 | Corsair RMx 850w | Fractal Meshify 2 Compact |
    Internet: Magenta | Fritz!Box 6660 Cable | 1028 Mbit/s / 53 Mbit/s |
    Handy: Google Pixel 6 | Magenta 5G | Yesss |
  • Angekommen auf der 2017er, danke!
  • Alles drauf jetzt :thumbup:
  • Und woher hast du denn das wissen?
    Bleib mal Ruhig ,und chill mal ;)
    Keiner hier ist ein Profi,das wissen hat man schon wenn man viel liest und testet.
    Ein HDMI Kabel überträgt ein digitales Signal... Bits und Bytes... keine Helligkeit. Es gibt genau zwei Zustände: entweder man hat Bild oder man hat kein Bild. Alles andere ist Einbildung.
    Aktuell gibt es sehr wenige Geräte die 2.1 Unterstützen.
    so jetzt denk was du willst,und bilde dir deine eigene Meinung was nicht stimmt.
    wie eigene meinung was nicht stmmt ? das sind tatsachen und keine meinung. da sieht man wie wenig ahnung du hast.
    hier mal ein bespiel
    und auch für den vollen objektbasierten klang brauchst du hdmi 2.1
    Nvidia Shield TV Pro (2019) - FireTV Stick 4K - Denon x2300w - Sony KD-65XG9505
    Nas: Asustor AS-6404T (22 TByte)
  • Ok hast wirklich viel Ahnung @Luene
    wusste wirklich nicht, das man für HDR , Hdmi 2.1 Kabel braucht :thumbup:
    lächerlich.
    HDR Hat man auch bei 2.0 Hdmi Kabel.Und ARC Geht ebenfalls mit HDMI 2.0
    Und 2.1 ist auch nur wirklich nützlich,wenn die Geräte das Unterstützen ...AVR ,TV,Mediaplayer usw.
    MFG
    knowing
    Mediaplayer: Zidoo Z9X -- TV: LG OLED83C17LA OLED TV (Flat, 83 Zoll) -- SAT Receiver: Gigablue Quad 4K -- AVR: Marantz SR7013 -- Heimkinosystem: DALI Zensor 5 (5.1.4) -- NAS Server: Synology 918+ (4x 8TB & 1x 4TB)
  • Gerade einmal kurz per Steam das neue Jedi Fallen Order angespielt - Hammergrafik und Hammerspiel!
    Leider zwischendurch etwas laggy gewesen.
    lächerlich.
    man lese mal richtig von was für hdr gesprochen wird und auch von arc ist nicht die rede. sondern von dynamischem hdr und earc und um das in vollem umfang zu realisieren braucht es nun mal 2.1 da 2.0 max 18 gbit/s schafft , 2.1 kann bis 48 gbit/s. genau wie für echten objektbasierten klang aber du verstehst das anscheinend nicht. erst richtig lesen dann nachdenken und dann erst das maul aufreißen :whistling:
  • Leute, zügelt euren Ton, geht langsam unter die Gürtellinie! 8|
  • Genau.
    aber dafür müssen die Geräte auch 2.1 Kompatibel sein;-)
    sonst hat es doch keinen Sinn wenn der eine das 2.1 kann und der andere nicht.Das ist doch klar oder nicht Mr. profi.
    So nun habe ich fertig;-)
    MFG
    knowing
  • Regelt das Privat bitte!
  • Und mal mit gefährlichen Halbwissen aufzuräumen, da viele HDMI 2.1 only Features zu 2.0 "gebackported" worden sind:
    - eARC geht auch bei HDMI 2.0, wenn Geräte dafür ein FW Update anbieten. Aktuelle AVR unterstützen es auch ohne. Und bei Yamaha wurde es auch für Vorjahresmodelle per FW nachgeliefert
    - Unser heutiges, marktreife dynamisches HDR geht auch bei HDMI 2.0 (HDR10+ und Dolby Vision)
    - HDMI 2.0 geht geht max 4k@60hz. Für 4k@120hz und 8k@60hz wird HDMI 2.1 benötigt
    - HDMI 2.0 kann keine variable Refreshratekagge
    - Sowohl HDMI 2.0 als auch 2.1 unterstützen alle zur Zeit gängigen Tonformate in vollen Umfang (DTS Master, DTS:X, Dolby TrueHD, Dolby Atmos, ...). HIer gibt es keinen Unterschied.
    Da die meisten Endgeräte bei den Usern daheim weder an der Set-Top-Box, AVR und TV eine 2.1 Anschluss haben, und selbst Ultra HD Blu-Rays meist nur geupscalte 2k Kagge ist, ist der Invest in ein HDMI 2.1 Kabel nur dann sinnvoll, wenn man bereits auf die Technik von Morgen setzt.
    Hat ein 2.0 Kabel an der Shield hier beim User Probleme gemacht, dann war und ist es ein scheiss Kabel davor gewesen. Und selbst bei guten Kabeln haben wir heutzutage eine Kabel-Lotterie.
    Und jetzt wieder bitte back to Topic. Geht euch hinter verschlossenen Türen mit HDMI Peitschen aushauen wenns euch gefällt.
    "I don't caretaker"
  • Hat das Update bei euch auch länger gedauert? Seit 15 min sehe ich Aktualisierung auf Shield Image 32.7.301.64.
    Nein, war in ca. 5 Minuten erledigt.
