Man kann auch im Setup einstellen, das die nicht in den Schlafmodus geht.
Auch das hab ich probiert, mit dem selben ergebniss, das blöde ist ja das das auch nur sporadisch auftritt. Aber gefühlt halt seit der 7.2 wesentlich öfter
Meine Shield bekam jetzt das 7.2.2 Update. Kein beta/Alpha Tester
+ 1 ... läuft gerade
SHIELD Experience Software Upgrade 7.2.2 (30.7.130.7) fixes the following bugs/issues on top of the previous 7.2.1 upgrade.
New Enhancements/Fixes:
• Fixes Keyboard/Mouse functionality for PUBG Mobile
• Fixes bug where colors are displayed incorrectly on Chrome/Puffin browsers
• Resolves storage quota issues when transferring files from PC to SHIELD
• Fixes issue where Dualshock 3 controller would not pair properly over Bluetooth
• Fixes issue affecting original Xbox One wired controller functionality
• Resolves issues where PLEX would not access content on NAS
• Addresses issues where NAS would not manually mount correctly
• Resolves bug where PLEX was not detecting Hauppauge WinTV-dualHD 1590
• Fixes bug where home screen is displayed while mounting network storage
• Fixes bug where Dynamic range advanced display setting was not working
• Improves network connectivity when connecting to router through local DNS or gateway
• Resolves issue where Sling app would not be available
• [Beta] Adds setting to automatically switch color modes (Settings > Developer Options > Colorimetry).
Known issues:
• Rare cases where system appears to hang on startup
• [SHIELD 2015 and SHIELD Pro] Rare cases of SD Card not recognized
• [SHIELD Pro] Accessory UI not present on pairing screen after factory reset
• Rare cases where USB drive is ejected.
• Some TV/Receivers may wake up after ~30 seconds after SHIELD sleeping
• Green line displayed at the bottom/right with specific content aspect ratio
• HDCP issues with specific TV models (Bauhn ATV65UHD-1217)
• Plex video playback from NAS takes 30 seconds to start.
Wurde der mSD Bug bei der 2015er bei euch behoben?
oha
Colormode switch beta plus Kodi mit seinen Video Optionen plus Sony xf9005 Video Optionen...
Das gibt eine Options Test Orgie auf dem Weg zum besten Bild..
Bin gespannt..
Nein...der MicroSD Bug wurde noch nicht behoben...es soll noch ein Test Beta Update auf Version 7.2.3 rauskommen...bin mal gespannt ob es dann klappen wird...oder wann der dann gestartet wird....wenn unser einer das nun richtig verstanden hat.
oha
Colormode switch beta plus Kodi mit seinen Video Optionen plus Sony xf9005 Video Optionen...Das gibt eine Options Test Orgie auf dem Weg zum besten Bild..
Bin gespannt..
Bei mir gibts nur ein Regler der dafür sorgt das alles dunkler ist, blasser und das Rot in Pink übergeht
Entwicklermodus
so
Colormetrie eingeschaltet
Shield Neustart
Live Tv an
Noch bevor das Bild da war, kommt aus den Boxen:
Ich parshippe jetzt!
back to topic:
das update lief auf meinem device mit SSD Umbau ohne Probleme
Edit:
für die Fragen zu den Einstellungen habe ich ein eigenes Thema eröffnet :
Rege Beteiligung erwünscht..
Alles anzeigenback to topic:
das automatische Farbraum switching ist ja als beta hinzugekommenDie Abstimmung der Komponenten TV/AVR/SHIELD und beteiligter apps bezüglich Auflösung, Farbraum und HDMI Formate ist mittlerweile verdammt komplex
mittlerweile listet mir die Shield 97 HDMI Modi..
Hardware: Shield, Denon AVR mit aktueller HDMI 2 Unterstützung,Sony XF9005 TV
Nutzung : live TV, Amazon prime, netflix, wenige Filme von FestplatteZiel : "bestes Bild" bei gleichzeitig möglichst wenig Auflösungs - Geswitche am TV
Apps für live TV (von TVHeadEnd Server) : live channels, Kodi, MrMchab für mich herausgefunden, daß der Sony TV das upscaling von content kleiner 4k machen soll
Sony : Cinema Home, Helligkeit 35, Farbe 52, Lichtsensor aus, Motion Flow 1,1, HDR, HDMI Videobereich, Farbraum: automatisch, Bildschärfe 65, Auflösung 50, Farbbrillianz aus
Kodi : Gui 1080 50 Hz, Whitelist alle 4k, 1080 50/60/59,94 Hz
zeigt live tv bei 1080pMrMC bietet nur 4k oder 1280x720 an, switcht aber bei live TV runter bis 720p
hat Probleme mit Dolby TrueHDlive channels nimmt vermutlich das, was in der shield voreingestellt ist.
Shield derzeit : 3840x2160 50 Hz YUV 422 12 Bit REC 2020
Umschaltung auf HDR content scheint zu funkktionierenBei dem HDMI Modus der Shield bin ich mir nicht sicher, ob ich das so lassen oder ändern soll ???
10 bit/12 Bit 50 oder 60 Hz ?? REC 2020 ?bei KODI hab ich irgendwo gelesen, die whitelist nicht mehr zu aktivieren ?
..bin echt am Schwimmen..
edit :
bei Musik Wiedergabe bin ich mir auch noch nicht ganz sicher, wie es "richtig" ist
lasse Musik gern auf alle 7 Boxen hochmischen.
momentan ist bei Kodi 7.1 channel eingestellt, audio upmixen aus
shield : Musik auf 5.1 hochmischen ein
oder das auf 2 Kanal lassen und nur am AVR Mode ändern ?
AVR steht auf DTS Neural X
ganz ehrlich mir geht es genauso! Vielleicht macht es Sinn hier ein neues Thema aufzumachen und die perfekten Beispiele pro TV und Erfahrungen zu teilen/archivieren. Ich weiß das es immer Unterschiede geben wird, aber auf Shield und TV sollte es ja eine Richtung geben. Hab einen Sony „sony 75w855c„ und würde mich freuen, wenn es jemanden gibt der weiß was ich wie wo einstellen sollte (Erfahrungen).
edit: Inhalt ausgelagert in eigenes Thema
Läuft Live TV gut? Hab auch einen neuen VU+, würde das gern testen.
Wurde das schon irgendwo ausgiebig besprochen, finde nichts dazu
Hab auch eine VU+ wenn auch keine aktuelle, aber an sich läuft das ganze eigentlich im Moment relativ geschmeidig
was willst du dazu wissen?
Benutze die Shield mit dem E2 PVR Client und es funktioniert inkl. EPG
Ich hatte das Plugin installiert (Für Vu+), die Verbindungswerte angegeben...aber läuft nicht.
Muss ich gleich mal testen, was genau angezeigt wird.
ich finde diese Colormodeswitching-Option nicht. kann mir jemand sagen wo sich diese bfindet? Danke!
Entwicklermenü aktivieren. Ich glaub shield Informationsmenu und dort paar mal ok drücken. Dann sagt er auch Entwicklermenü freigeschaufelt.
Und dort kann man dann die Option aktivieren.
Mehr weiß ich gerade nicht aus dem Kopf. Gerne heute Abend genauer, falls nicht jemand schneller ist.
Websuche
Der Kniff basiert auf der alten – und völlig behämmerten – Android-Marotte, „Entwickler“ zu werden. Das funktioniert wie bei jedem anderen Android-Gerät auch: Geht in die Einstellungen, ruft die Systeminformationen auf und klickt dann so lange auf den Eintrag „Build“, bis die Nachricht erscheint, dass Ihr nun Entwickler seid.
