Extended Info Script Fehler beim starten von Kodi 17
    immer beim starten von Kodi 17 (Nvidia Box) erscheint ein Extended Info Script Fehler, könnt ihr mir bitte sagen wie ich das beheben kann?
    vielen Dank im voraus!
    19:32:15.894 T:176759465200 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    Error Type: <type 'exceptions.ValueError'>
    Error Contents: No JSON object could be decoded
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py", line 134, in <module>
    Main()
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py", line 31, in __init__
    listitems = process.start_info_actions(info, self.params)
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…/lib/process.py", line 61, in start_info_actions
    return tmdb.get_movies("popular")
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…b/TheMovieDB.py", line 1180, in get_movies
    return handle_movies(response["results"], False, None)
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…b/TheMovieDB.py", line 302, in handle_movies
    sortkey=sortkey)
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…di65/localdb.py", line 316, in merge_with_local
    get_list(["originaltitle", "imdbnumber"]))
    File "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…di65/localdb.py", line 293, in get_compare_info
    dct["otitles"] = json.loads(addon.get_global("%s_otitles.JSON" % media_type))
    File "/home/jenkins/workspace/Android-ARM64/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/json/__init__.py", line 339, in loads
    File "/home/jenkins/workspace/Android-ARM64/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/json/decoder.py", line 364, in decode
    File "/home/jenkins/workspace/Android-ARM64/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/json/decoder.py", line 382, in raw_decode
    ValueError: No JSON object could be decoded
    19:32:16.066 T:176759465200 WARNING: CPythonInvoker(6, /storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py): the python script "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
    19:32:16.082 T:176758428912 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=popularmovies
    19:32:19.795 T:176630088944 NOTICE: script.module.youtube.dl: youtube_dl core version: 2018.04.25
    19:32:20.194 T:176761537776 WARNING: CPythonInvoker(10, /storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py): the python script "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
    19:32:23.599 T:176757392624 NOTICE: AddOnLog: PVR IPTV Simple Client: Playlist file path is not configured. Channels not loaded.
    19:32:24.040 T:176675972336 NOTICE: script.module.youtube.dl: youtube_dl core version: 2018.04.25
    19:32:24.661 T:176757392624 NOTICE: Start - EPG thread started
    19:32:24.890 T:176630088944 WARNING: CPythonInvoker(11, /storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py): the python script "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
    19:32:25.159 T:176675972336 WARNING: CPythonInvoker(12, /storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py): the python script "/storage/emulated/0/Android/data/http://org.xbmc.kodi/files/.kodi/ad…dinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
