VLC Player als externer Player (Fire tv Stick)
    habe folgendes in die playercorefactory.xlm auf meinem Fire TV Stick geschrieben! Leider startet der VLC player nicht wenn ich einen Film in Kody starte... stimmt der Pfad von dem VLC Player nicht? Wenn ja wie ist der korrekte pfad??
    Vielen dank schon mal für die Hilfe!
    Externer Inhalt kodianer.de
    <playercorefactory>
    <players>
    <player name="MXPlayerFree" type="ExternalPlayer" audio="false" video="true">
    <filename>com.mxtech.videoplayer.ad</filename>
    <hidexbmc>true</hidexbmc>
    <playcountminimumtime>120</playcountminimumtime>
    </player>
    <player name="MXPlayerPro" type="ExternalPlayer" audio="false" video="true">
    <filename>com.mxtech.videoplayer.pro</filename>
    </player>
    <player name="TPlayer" type="ExternalPlayer" audio="false" video="true">
    <filename>com.tiantian.android.player.app</filename>
    </player>
    <player name="DicePlayerFree" type="ExternalPlayer" audio="false" video="true">
    <filename>com.inisoft.mediaplayer.trial</filename>
    </player>
    <player name="VLCPlayer" type="ExternalPlayer" audio="false" video="true">
    <filename>com.vlcforandroid.vlcdirectprofree</filename>
    </player>
    <player name="DicePlayerPaid" type="ExternalPlayer" audio="false" video="true">
    <filename>com.inisoft.mediaplayer.a</filename>
    </player>
    <player name="RockPlayerLite" type="ExternalPlayer" audio="false" video="true">
    <filename>com.redirectin.rockplayer.android.unified.lite</filename>
    </player>
    <player name="RockPlayer" type="ExternalPlayer" audio="false" video="true">
    <filename>com.rockplayer</filename>
    </player>
    <player name="BSPlayerFree" type="ExternalPlayer" audio="false" video="true">
    <filename>com.bsplayer.bspandroid.free</filename>
    </player>
    <player name="MoboplayerFree" type="ExternalPlayer" audio="false" video="true">
    <filename>com.clov4r.android.nilz</filename>
    </player>
    <player name="mVideoplayerFree" type="ExternalPlayer" audio="false" video="true">
    <filename>afzkl.development.mVideoPlayer</filename>
    </player>
    <player name="Vplayer" type="ExternalPlayer" audio="false" video="true">
    <filename>me.abitno.vplayer.t</filename>
    </player>
    <player name="WondersharePlayer" type="ExternalPlayer" audio="false" video="true">
    <filename>com.wondershare.player</filename>
    </player>
    <player name="ArchosVideo" type="ExternalPlayer" audio="false" video="true">
    <filename>com.archos.mediacenter.video</filename>
    </player>
    <player name="SopCast" type="ExternalPlayer" audio="false" video="true">
    <filename>org.sopcast.android</filename>
    </player>
    <player name="DaroonPlayer" type="ExternalPlayer" audio="false" video="true">
    <filename>com.daroonplayer.dsplayer</filename>
    </player>
    </players>
    <rules action="prepend">
    ********** EDIT THIS SECTION **********
    <rule protocols="smb" player="VLCPlayer" />
    <rule dvdimage="true" player="VLCPlayer"/>
    <rule protocols="rtmp" player="VLCPlayer"/>
    <rule protocols="rtsp" player="VLCPlayer" />
    <rule protocols="sop" player="VLCPlayer" />
    <rule internetstream="true" player="VLCPlayer" />
    <rule video="true" player="VLCPlayer"/> <!-- Default for anything else not listed -->
    </rules>
    </playercorefactory>
  • Ich frage mich was wäre der Grund dies zu tun?
    Es ist zwar keine Antwort aber trotzdem würde es mich brennend interessieren.
    Weil gerade auf dem FireTV Stick und dessen begrenzten RAM glaube ich das man abgesehen von der Möglichkeit es zu können sehr schnell an seine Grenzen kommt.
  • Hallo, ich möchte Videos von meiner FRITZ.NAS mit kodi auf dem Fire Stick abspielen (SMB Freigabe). Die Streams ruckeln alle paar Sekunden und brauchen lange nachzuladen. Unter VLC laufen sie gut. Deshalb würde ich gerne die Videos mit VLC starten. Aber mein File scheint nicht zu funktionieren. Kodi gibt beim Abspielversuch jedes getesteten Films (mp4) eine Fehlermeldung aus (Das Video kann nicht abgespielt werden oder so ähnlich). Es ist wohl ein Fehler in meiner playercorefactory.xml. Ich bitte um Hilfe.
