Im VLC Player funktioniert das Manifest was du verlinktest.
ZDF Mediathek funktioniert nicht mehr
GOOFY84 -
7. Oktober 2017 um 21:23 -
Ich bekomme im ZDF Addon folgende Meldung:
Alles anzeigen17:21:18.781 T:1727001328 WARNING: Repository Kodi Add-on repository uses plain HTTP for add-on downloads - this is insecure and will make your Kodi installation vulnerable to attacks if enabled! 17:21:34.830 T:1539302128 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.IndexError'> Error Contents: list index out of range Traceback (most recent call last): File "/home/osmc/.kodi/addons/plugin.video.zdf_de_lite/default.py", line 5, in <module> libzdf.list() File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdf.py", line 102, in list File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdf.py", line 80, in libZdfListChannelDateVideos File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdf.py", line 42, in libZdfListPage File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdfjsonparser.py", line 36, in parsePage response = getU(url,True) File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdfjsonparser.py", line 18, in getU libzdftokengrabber.grepToken() File "/home/osmc/.kodi/addons/script.module.libzdf/lib/libzdftokengrabber.py", line 8, in grepToken tokenPlayer = re.compile('"apiToken": "(.+?)"', re.DOTALL).findall(response)[0] IndexError: list index out of range -->End of Python script error report<-- 17:21:34.845 T:1547690736 ERROR: GetDirectory - Error getting plugin://plugin.video.zdf_de_lite/?channel=ZDF&datum=0&mode=libZdfListChannelDateVideos&yyyymmdd=2018-12-24 17:21:34.847 T:1918312448 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.zdf_de_lite/?channel=ZDF&datum=0&mode=libZdfListChannelDateVideos&yyyymmdd=2018-12-24) failed
Egal ob Kodi 17 oder Kodi 18
OS: OSMC
RPi 3libzdf ist auf 2.1.8
membranes repo ist aktiv und alles auf auto update -
Vor ein paar Wochen hat ein Mit-Nerd ein paar lib* Updates bereitgestellt, darunter auch fürs ZDF. Bin zu faul zum Suchen, darum als Anhang. Unithek funzt damit bei mir. Vielleicht hilft's Dir ja auch.
Funktioniert wunderbar...vielen Dank
...und Frohe Weihnachten -
Danke hat mein Problem mit der ZDF Mediathek auch gefixt!
@vdr.tuxnet: Kommt das demnächst in die Repo?
scheint im Repo zu sein - zumindest gehts bei mir wieder
