Ich habe das Problem, das die Streams von Radio Bob nicht abgespielt werden und eine Fehlermeldung kommt. Ich habe mal versucht den entsprechenden Teil der Logdadei auszuschneiden:
13:15:01.615 T:1443709856 NOTICE: [xbmcswift2] Request for "/stations/my/" matches rule for function "show_my_stations"
13:15:01.615 T:1443709856 NOTICE: [plugin.audio.radio_de] __add_stations started with 27 items
13:15:06.371 T:1443709856 NOTICE: [xbmcswift2] Request for "/station/39031" matches rule for function "get_stream_url"
13:15:06.373 T:1443709856 NOTICE: [plugin.audio.radio_de] get_station_by_station_id started with station_id=39031
13:15:06.377 T:1443709856 NOTICE: [plugin.audio.radio_de] __api_call started with path=broadcast/getbroadcastembedded, param={'broadcast': '39031'}
13:15:06.377 T:1443709856 NOTICE: [plugin.audio.radio_de] __urlopen opening url=http://radio.de/info/broadcast…broadcast=39031
13:15:06.482 T:1443709856 NOTICE: [plugin.audio.radio_de] get_stream_url result: http://streams.radiobob.de/bob-grunge/mp3-128/radiode/
13:15:30.090 T:1962287104 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
13:15:30.094 T:1962287104 ERROR: Open - error probing input format, http://streams.radiobob.de/bob-grunge/mp3-128/radiode/
13:15:30.095 T:1962287104 ERROR: Init: Error creating demuxer
13:15:30.095 T:1962287104 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://streams.radiobob.de/bob-grunge/mp3-128/radiode/
13:15:30.095 T:1962287104 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
13:15:30.095 T:1962287104 ERROR: Playlist Player: skipping unplayable item: 25, path [plugin://plugin.audio.radio_de/station/39031]
13:15:33.175 T:1443709856 NOTICE: [xbmcswift2] Request for "/" matches rule for function "show_root_menu"
13:15:34.405 T:1365480352 ERROR: Unable to find plugin
13:15:34.405 T:1962287104 ERROR: GetDirectory - Error getting plugin://
13:15:34.406 T:1962287104 ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
13:16:16.187 T:1426932640
wie kann ich das Problem lösen?
