ALSA HDMI YAMAHA RX-A1030 5.1 Sound Problem
  • Hi Guys,
    currently I´m trying to set ALSA working for squeezelite, which works perfect, if I use the standart Audio Jack.
    If I`m using HDMI to get the sound working over the YAMAHA I get the squeezelite sound as expected with the /flash/config.txt settings to:
    dtparam=audio=on
    But when I´m playing a real 5.1 or 7.1 sound over Libreelec (They share one device), I can´t get any good results.
    Is it possible to configure the /flash/config.txt in a way, that only squeezelite uses the ALSA driver and that Libreelec isn´t using ALSA at all.
    I´m also a bit confused, what dtparam=audio=on really does.
    Maybe another solution could be to set the Autostart for Squeezelite in a way that only squeezelite uses the ALSA driver.
    Hopefully someone is as sound nerdy as me and could help :thumbup:
