seid ein paar Tagen habe ich das Problem das die CPU Auslastung beim Start von Kodie meist 10 Minuten bei 100 Prozent liegt. Ich verwende den Skin Titan. Vorher hatte ich den Effekt nicht.
Hier mal ein Auszug aus dem Log:
16:05:23 T:5236 NOTICE: Running database version Addons20
16:05:23 T:5236 NOTICE: Running database version ViewModes6
16:05:23 T:5236 NOTICE: Running database version Textures13
16:05:23 T:5236 NOTICE: Running database version MyMusic56
16:05:23 T:5236 NOTICE: Running database version MyVideos99
16:05:23 T:5236 NOTICE: Running database version TV29
16:05:23 T:5236 NOTICE: Running database version Epg11
16:05:25 T:5236 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:05:25 T:6288 NOTICE: PVRManager - starting up
16:05:25 T:5236 NOTICE: ActiveAE DSP - starting
16:05:25 T:5236 ERROR: CScriptInvocationManager::ExecuteAsync - Not executing non-existing script C:\Users\Kodi\AppData\Roaming\Kodi\addons\plugin.video.youtube\startup.py
16:05:25 T:5236 NOTICE: initialize done
16:05:26 T:6296 NOTICE: AddOnLog: DVBViewer Client: Checking backend version...
16:05:26 T:6296 NOTICE: AddOnLog: DVBViewer Client: Version: 18940416
16:05:26 T:6296 WARNING: PVR::CPVRClient::GetAddonProperties - Addon DVBViewer:127.0.0.1 does not support timer types. It will work, but not benefit from the timer features introduced with PVR Addon API 2.0.0
16:05:26 T:5236 NOTICE: Running the application...
16:05:26 T:5236 WARNING: Trying to add unsupported control type 1
16:05:27 T:5236 WARNING: Previous line repeats 12 times.
16:05:27 T:5236 NOTICE: starting zeroconf publishing
16:05:27 T:5236 NOTICE: WebServer: Started the webserver
16:05:27 T:5236 NOTICE: starting upnp client
16:05:27 T:5236 NOTICE: starting upnp server
16:05:27 T:5236 NOTICE: starting upnp controller
16:05:27 T:5236 NOTICE: starting upnp renderer
16:05:27 T:6444 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:05:27 T:6444 NOTICE: UDP: Listening on port 9777
16:05:30 T:6268 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
16:05:36 T:6276 NOTICE: Skin Helper Backgrounds --> BackgroundsUpdater - started
16:05:40 T:6944 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
16:05:40 T:6260 NOTICE: Skin Helper Service --> Skin Helper Service version 1.0.145 started
16:05:42 T:6248 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
16:05:42 T:6248 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ========
16:05:42 T:6248 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 16.1 Git:20160424-c327c53
16:05:42 T:6248 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.32
16:06:01 T:6288 NOTICE: EPG::CEpgContainer::Start - EPG thread started
16:10:53 T:6288 ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.msftncsi.com/ncsi.txt
16:10:59 T:6288 ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.w3.org/
16:11:20 T:6288 ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.msftncsi.com/ncsi.txt
16:11:25 T:6288 ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.w3.org/
16:17:36 T:5236 WARNING: Trying to add unsupported control type 1
16:17:39 T:7140 WARNING: Previous line repeats 5 times.
16:17:39 T:7140 WARNING: Attempt to use invalid handle -1
16:17:58 T:5236 WARNING: Previous line repeats 2 times.
16:17:58 T:5236 ERROR: DXGI_ERROR_INVALID_CALL
