Simple IPTV-Problem
    versuche über den PVR-Simple IPTV Client zu streamen. Jedoch werden die Streams nicht gestartet. Das ganze auf einem Macbook unter OSX
    Das Log meldet:
    18:00:25.506 T:140735687615424 DEBUG: PVR - Destroy - destroying PVR add-on 'IPTV Simple PVR Add-on:connected'
    18:00:25.506 T:140735687615424 DEBUG: SECTION:UnloadDll(/Applications/http://Kodi.app/Contents/Resources/Kodi/addons/pvr.iptvsimple/pvr.iptvsimple.2.4.4.dylib)
    18:00:25.506 T:140735687615424 INFO: ADDON: Dll Destroyed - PVR IPTV Simple Client
    18:00:25.506 T:140735687615424 DEBUG: CSettingsManager: requested setting (epg.daystodisplay) was not found.
    18:00:25.506 T:140735687615424 DEBUG: PVRManager - destroyed
    18:00:25.506 T:140735687615424 DEBUG: ActiveAE DSP - destroyed
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000002e4480 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000efe80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000ef680 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000ef580 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000ef180 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000eec00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000eea00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000ee600 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.508 T:140735687615424 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6000000ee480 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
    18:00:25.509 T:123145539330048 DEBUG: Thread Announce 123145539330048 terminating
    18:00:25.509 T:140735687615424 NOTICE: application stopped...
    18:00:25.536 T:140735687615424 DEBUG: SECTION:UnloadDll(libcurl.4.dylib)
    wo liegt das Problem
  • wo liegt das Problem
    Bitte mal ein komplettes [definition=9,2]kodi.[definition='1','0']log[/definition][/definition] mit aktiviertem Debugging auf pastebin,.com hochladen - aus solch kurzen Ausschnitten sich was herauszufieseln, was die Ursache sein könnte, ist meist nicht möglich.
    Danke
  • Einfach auf http://www.pastebin.com gehen und in das große leere Textfeld den Inhalt des Logfiles (z. B. per copy & paste) reinkopieren.
    Dann auf "Create new Paste" klicken und fertig.
    Man erhält dann in der URL Zeile (Adresszeile) des Browsers "seine" URL für den neuen Paste - z. B. http://pastebin.com/y5mvWtAk
    Mehr dazu: https://de.wikipedia.org/wiki/Pastebin
    Und: http://pastebin.com/faq
    Geht auch "bequemer" per SSH: http://kodi.wiki/view/Log_file/…ia_command_line
    1) pastebinit installieren mit  sudo apt-get install pastebinit -y
    2) Logfile direkt aus der SSH Session an pastebin schicken mit cat $HOME/.kodi/temp/kodi.[definition='1','0']log[/definition] | pastebinit bzw. cat $HOME/.Kodi/temp/kodi.[definition='1','0']log[/definition] | pastebinit
  • Indem du sie deinstallierst ;)
    Client2:RPI2|LE 7.0.2
    NAS 1: DS211J
    SKIN: Estuary.Refresh
    Display: Samsung 55 Zoll
    PVR: VU Duo 2|3TB
    FB: Harmony 600
    Amp: OnkyoTX626
    Center VOKAL
    Front: ZENZOR5
    Surround: ZENZOR1
