Kodi v17 “Krypton” Beta 5
  • Quelle: https://kodi.tv/kodi-v17-krypton-beta-5/
    Download: http://mirrors.kodi.tv/releases/win32…ypton_beta5.exe
    Externer Inhalt kodi.tv
    Kodi 17 features a huge amount of work in areas like video playback, live TV and PVR/DVR, the music library, skinning and more. It features a new default skin, as well as a new default touchscreen skin, named Estuary and Estouchy, respectively. With all this work done over the months some bugs might slip through and were hoping to quickly squash the coming beta releases. The changes for this fifth beta are the result of the continuous effort from the developers, either from inside the team or outside to get v17 into final release shape. and any outside. We sure would like to thank every one involved with either development, testing or simply helping out others with question. Below is a condensed list of fixes and changes done in this beta 5 release.
    Fixes done in this Beta 5:
    Fix playback of HLS streams
    • Fix skin settings not loading when “reload skin” was triggered
    • Fix segfault on EOF for video caused by postprocessing
    • Fix possible crash on Android when other Android apps had missing icons
    • Change splash screen text once per second to show it’s busy doing database and add-on upgrades instead of just static text.
    • Fix missing binary add-ons like PVR and controller handling on Windows
    • Add back seek to time using numeric input on video files
    Microsoft has rolled out a fix for users of the Kodi UWP version in combination with AMD videocard that had BSOD. For more information see: Blue screen with error code 0×139
    Known problems
    Upgrading the skin you are currently using fails on Windows.
    • Upgrading any add-on currently fails on Windows.
    • Possible video freezes on Raspberry Pi and Android.
    We are trying to find the cause solve these problems. Of course there are some more however these are the most noticeable ones. Remember this is still Beta software so please be patient.
    For completeness here are the fixes done in previous beta
    Fixes done in this Beta 4:
    Fix certain types of 16bit encoded passthrough streams on OSX
    • Fix activate/deactivate on read only timers
    • Fix reading interlaced modes from defaultsettings when set to none
    • Fix compilation albums, last played rules and fix missing sort order rules in smartplaylists
    • Fix relative seeks on video playback
    • Fix info dialog for recordings on home screen
    • Don’t load inputstreams on startup if they are disabled
    • Fix subsequent seeks with video playback
    • Explicitly check for DTS capability for making settings visible
    • Add ARMv8A 64bit builds for Android
    • Add GetLastModifiedDate to the webserver
    • Fix playback of DVD ISO files
    • Fix focus of list items in media windows (like plugins)
    • Change spinners options in smartplaylist editors to a select menu
    • Add workaround for AMD/ATI cards regarding interlaced content
    • Fix gapless playback for music
    • Fix controller on NVIDIA Shield TV not working after it when to sleep
    • Fix video playback when skipping beyond end of file on mp4 videos
    • Improve crashlog reporting for UWP app in Windows Store
    • Export max ratings to NFO files by default
    • Fix hardware decoding on some mpeg2 files and DVDs for AMD/ATI cards as their drivers aren’t that good
    • Fix aspect ratio calculation for 3D modes
    • Fix video playback in image slideshows
    • Fix channel group change in PVR
    • Fix several memory leaks
    A full list can be found here
    What’s new?
    This round we didn’t really add new features as the focus was to further improve our code and solving possible bugs. We do have some more improvements lined up for next beta so stay tuned…….
    Windows Store
    In case you missed the big news some time ago, Kodi got added to the Windows Store as a Desktop Bridge UWP app. It is still the same Kodi version you are used to use, without any limitations. Although it is still possible (and always will be) to download and install Kodi from our website, it is now also possible for Windows 10 users to download and install Kodi from the Windows Store. This brings a few benefits, such as automatic updating. The Windows Store application uses the same userdata as the version from our website so you can switch between the two versions without issues. NOTE: This also means that if you are currently running Kodi v16 and want to try out the Windows Store version, your Kodi databases and add-ons will be upgraded to the v17 versions. You might want to make a backup of the userdata before! You can read the full announcement here: Kodi goes Windows Store
    NOTE: Since it takes a bit of time to publish in Windows Store you might need to wait a bit till the update is available.
    All in all this Beta 5 might not seem very excited but that’s how it’s supposed to be. We’re simply focusing more on stability and working out the details than keep adding bells and whistles.
    Conclusion
    As previously noted, this is only a small summary of all the improvements in Kodi 17. For more, see the Alpha 2 and Alpha 3 posts. Should you want to download and install this build please visit our download page. You can install these build just on top of your current Kodi installation.
    Official Kodi 17.0 development downloads (near the bottom of the page)
    LibreELEC Raspberry Pi / x86 versions can be found here
    Bug reports
    Please report any problems on our forum http://forum.kodi.tv and not on the release announcement as it is not a reporting or help section. Don’t forget we also have some official tablet/phone remote controls for both Android and iOS. You can find the links to them on the download page.
    Donations or getting involved
    Getting involved is quite easy. Simply take the plunge and start using these 17.0 Krypton builds. If you use these builds, we encourage you to report problems with these builds on our forum first and after that, if asked, submit bugs on Trac (following this guide: How to submit a bug report). Do note that we need detailed information so we can investigate the issue. We also appreciate providing support in our Forums where you can. You can of course also follow or help promote Kodi on all available social networks. Read more on the get involved page. We are always happy to receive a donation by which you show your support and appreciation, and t-shirts and Raspberry Pi cases may still be found on the sidebar for purchase. All donations and other income goes towards the XBMC foundation and are typically used for travel to attend conferences, any necessary paperwork and legal fees, purchasing necessary hardware and licenses for developers and hopefully the yearly XBMC Foundation Developers Conference.
    Einmal editiert, zuletzt von SkyBird1980 (29. Oktober 2016 um 13:25)
  • Danke für die Info...Skybird :) ...diese Beta läuft nun um Meilensteine besser als die Beta 4 für Windows 10...jedenfalls wat Zatto PVR Cient und 7TV (Input Stream) betrifft.
  • ja, aber vorsicht:
    Known problems
  • Das eigentliche Problem das unser einer zur Zeit hat...weil Kodi 16.1 und Kodi 17 Beta gleichzeitig installiert ist...das wenn man in Kodi 17 Beta einen Skin auswählt wie den Estuary...dann wird mir die guisettings.xml Datei unter den userdata Ordner zerschossen und habe danach Probleme beim Start der Kodi Version 16.1 mit einen anderen Skin.
    Einmal editiert, zuletzt von Ronny (29. Oktober 2016 um 14:26)
  • Habe nun den Unterordner portable_data angelegt...bekomme Kodi.exe -p mit diesen Parameter aber nicht gestartet...was oder wie könnte man dat hinbekommen?
  • Habe es versucht...aber bei mir meldet sich windows 10 beim übernehmen mit Verknüpfungs Problem... diese Verknüpfung ist ungültig...ohne -p klappt es allerdings.
    Wollte es so übernehmen:
    "C:\Program Files (x86)\Kodi3\kodi.exe -p"
  • Ok...das mit der Verknüpfung hat nun geklappt...danke...aber wenn man nun auf diese Verknüpfung klickt...dann kommt:
    Kodi
    Error: Unable to create application..Exiting
  • Stimmt der Ausführen in Pfad denn? Wie in meinem Screenshot?! :D
    (oder läuft Kodi noch vieleicht versteckt -> Taskmanager gucken)
  • Im Taskmanager läuft keine andere Kodi Version bevor man die Verknüpfung:
    Ziel "C:\Program Files (x86)\Kodi3\kodi.exe" -p
    nun so starten möchte.
  • Wenn Du in Windows 10 im portable moode nutzen möchtest und die Meldung "Error: Unable to create application..Exiting" bekommst, dann fehelen die Schreibrechte in dem Kodi Verzeichnis.
    Das ist ein Schutz von Win 10 das im Programmverzeichnis keine Schreibrechte sind.
    Du kannst aber für diese Verzeichnis in den Sicherheitseinstellungen dem User Schreibrechte geben. Dann klappt es auch mit Kodi im Programme..
    Mein Heimkino
  • hat schon wer mit der Shield getestet, laufen die HD Tonformate ordentlich?
    Philips 77" Oled 806, Arcam AVR 31, VU Solo4K, Oppo UDP 203, Play Station 5, Nvidia Shield 2019, B&W 704 S3, B&W HTM71 S3, B&W 707 S3 ,B&W DB2D, BlueSound Flex 2i, BlueSound Pulse 2, Synology DS 718+
  • hm, da deutsch als addon heruntergeladen wird könntest du recht haben. da ich das schon habe hab ich das natürlich nicht gemerkt.
  • Richtig. :D
    Allerdings habe ich gerade die Beta 5 drauf, und zumindest das yt-download addon hat sich aktualisiert... ich bin nun verwyrrt :D
