Das ist kein [definition='1','4']Debuglog[/definition].
Die Stelle, wo du das Addon installierst ist wichtig.
Sorry, 2. Versuch:
07:02:40 T:5732 WARNING: CSkinInfo: failed to load skin settings
07:02:40 T:5732 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
07:02:40 T:5732 ERROR: JSONRPC: Unable to parse JSON Schema definition for ""
07:02:40 T:5732 ERROR: JSONRPC: Invalid JSON Schema definition for method ""
07:02:40 T:5732 NOTICE: initialize done
07:02:40 T:5732 NOTICE: Running the application...
07:02:40 T:5732 NOTICE: starting upnp client
07:02:40 T:7020 NOTICE: ES: Starting UDP Event server on port 9777
07:02:40 T:7020 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
07:02:40 T:4028 ERROR: XFILE::CDirectory::GetDirectory - Error getting
07:02:42 T:5584 ERROR: CAddonInstallJob[metadata.album.universal]: failed to install dependency metadata.common.musicbrainz.org
07:02:42 T:5584 ERROR: XFILE::CDirectory::Create - Error creating C:\
07:03:27 T:5732 ERROR: Previous line repeats 216 times.
07:03:27 T:5732 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
07:03:27 T:5732 NOTICE: Enabled debug logging due to GUI setting. Level 2.
07:03:27 T:5732 DEBUG: ------ Window Init () ------
07:03:38 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
07:03:38 T:5732 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
07:03:38 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
07:03:38 T:5732 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:03:38 T:5732 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
07:03:38 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
07:03:38 T:5732 DEBUG: ------ Window Init (Settings.xml) ------
07:03:38 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
07:03:42 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
07:03:42 T:5732 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
07:03:42 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
07:03:43 T:5732 DEBUG: ------ Window Deinit (Settings.xml) ------
07:03:43 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
07:03:43 T:5732 DEBUG: ------ Window Init (Home.xml) ------
07:03:43 T:5732 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
07:03:43 T:5732 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
07:03:43 T:5732 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
07:03:43 T:5732 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
07:03:43 T:5264 DEBUG: Thread JobWorker start, auto delete: true
07:03:43 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
07:03:44 T:5732 DEBUG: ------ Window Init (Pointer.xml) ------
07:03:45 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:45 T:5732 DEBUG: Activating window ID: 11100
07:03:45 T:5732 DEBUG: ------ Window Deinit (Home.xml) ------
07:03:45 T:5732 DEBUG: ------ Window Init (Custom_1100_AddonLauncher.xml) ------
07:03:45 T:5732 INFO: Loading skin file: Custom_1100_AddonLauncher.xml, load type: KEEP_IN_MEMORY
07:03:45 T:5732 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
07:03:45 T:5732 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
07:03:45 T:5732 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
07:03:45 T:5732 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
07:03:45 T:3256 DEBUG: Thread JobWorker start, auto delete: true
07:03:45 T:5732 DEBUG: CDirectoryProvider[addons://outdated/]: refreshing..
07:03:45 T:6904 DEBUG: Thread JobWorker start, auto delete: true
07:03:45 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
07:03:45 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 7 ms
07:03:48 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:48 T:5732 DEBUG: Activating window ID: 10040
07:03:49 T:5732 DEBUG: ------ Window Deinit (Custom_1100_AddonLauncher.xml) ------
07:03:49 T:5732 DEBUG: ------ Window Init (AddonBrowser.xml) ------
07:03:49 T:5732 INFO: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
07:03:49 T:5732 DEBUG: CGUIMediaWindow::GetDirectory (addons://)
07:03:49 T:5732 DEBUG: ParentPath = []
07:03:49 T:5732 DEBUG: CAddonMgr::GetAvailableUpdates took 11 ms
07:03:49 T:3888 DEBUG: Thread BackgroundLoader start, auto delete: false
07:03:49 T:3888 DEBUG: Thread BackgroundLoader 3888 terminating
07:03:50 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:50 T:5732 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/)
07:03:50 T:5732 DEBUG: ParentPath = [addons://]
07:03:50 T:6272 DEBUG: Thread BackgroundLoader start, auto delete: false
07:03:50 T:6272 DEBUG: Thread BackgroundLoader 6272 terminating
07:03:51 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action wheeldown
07:03:53 T:5732 DEBUG: Previous line repeats 3 times.
07:03:53 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:53 T:5732 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/kodi.inputstream)
07:03:53 T:5732 DEBUG: ParentPath = [addons://user/]
07:03:53 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 12 ms
07:03:53 T:6392 DEBUG: Thread BackgroundLoader start, auto delete: false
07:03:53 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.mpd\icon.png
07:03:53 T:6392 DEBUG: Thread BackgroundLoader 6392 terminating
07:03:53 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\icon.png
07:03:54 T:6904 DEBUG: Previous line repeats 1 times.
07:03:54 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.mpd\icon.png
07:03:54 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:54 T:5732 DEBUG: ------ Window Init (DialogAddonInfo.xml) ------
07:03:54 T:5732 INFO: Loading skin file: DialogAddonInfo.xml, load type: KEEP_IN_MEMORY
07:03:57 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:03:57 T:5732 DEBUG: ADDON: Dll Initializing - InputStream MPEG DASH
07:03:57 T:5732 DEBUG: SECTION:LoadDLL(C:\Program Files (x86)\Kodi\addons\inputstream.mpd\inputstream.mpd.dll)
07:03:57 T:5732 ERROR: ADDON: Dll InputStream MPEG DASH - Client returned bad status (6) from Create and is not usable
07:03:57 T:5732 DEBUG: ------ Window Init (DialogConfirm.xml) ------
07:03:57 T:5732 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
07:04:00 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:00 T:5732 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
07:04:00 T:5732 DEBUG: CAddonMgr: enabled inputstream.mpd
07:04:00 T:5732 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/kodi.inputstream)
07:04:00 T:5732 DEBUG: ParentPath = [addons://user/kodi.inputstream]
07:04:00 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 12 ms
07:04:00 T:4232 DEBUG: Thread BackgroundLoader start, auto delete: false
07:04:00 T:4232 DEBUG: Thread BackgroundLoader 4232 terminating
07:04:00 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.mpd\icon.png
07:04:00 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\icon.png
07:04:02 T:5732 DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
07:04:02 T:5732 DEBUG: CInputManager::OnKey: backspace (0xf008) pressed, action is Back
07:04:02 T:5732 DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0000, modifier: 0x0
07:04:02 T:5732 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:04:03 T:5732 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
07:04:03 T:5732 DEBUG: ------ Window Init (Pointer.xml) ------
07:04:03 T:5264 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\icon.png
07:04:04 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:04 T:5732 DEBUG: ------ Window Init (DialogAddonInfo.xml) ------
07:04:04 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\icon.png
07:04:06 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:06 T:5732 DEBUG: ADDON: Dll Initializing - InputStream SmoothStreamingMedia
07:04:06 T:5732 DEBUG: SECTION:LoadDLL(C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\inputstream.smoothstream.dll)
07:04:06 T:5732 ERROR: ADDON: Dll InputStream SmoothStreamingMedia - Client returned bad status (6) from Create and is not usable
07:04:06 T:5732 DEBUG: ------ Window Init (DialogConfirm.xml) ------
07:04:08 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:08 T:5732 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
07:04:08 T:5732 DEBUG: CAddonMgr: enabled inputstream.smoothstream
07:04:08 T:5732 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/kodi.inputstream)
07:04:08 T:5732 DEBUG: ParentPath = [addons://user/kodi.inputstream]
07:04:08 T:5264 DEBUG: CAddonMgr::GetAvailableUpdates took 11 ms
07:04:08 T:2536 DEBUG: Thread BackgroundLoader start, auto delete: false
07:04:08 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.mpd\icon.png
07:04:08 T:2536 DEBUG: Thread BackgroundLoader 2536 terminating
07:04:08 T:6904 DEBUG: CTextureCacheJob::GetImageHash - unable to stat url C:\Program Files (x86)\Kodi\addons\inputstream.smoothstream\icon.png
07:04:25 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
07:04:25 T:5732 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
07:04:25 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
07:04:25 T:5732 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:04:25 T:5732 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
07:04:26 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
07:04:27 T:5732 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
07:04:27 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
07:04:27 T:5732 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
07:04:27 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
07:04:27 T:5732 DEBUG: ------ Window Init (Custom_1100_AddonLauncher.xml) ------
07:04:27 T:5732 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
07:04:27 T:5732 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
07:04:27 T:5732 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
07:04:27 T:5732 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
07:04:27 T:5732 DEBUG: CDirectoryProvider[addons://outdated/]: refreshing..
07:04:27 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
07:04:27 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 14 ms
07:04:27 T:6904 DEBUG: CAddonMgr::GetAvailableUpdates took 7 ms
07:04:36 T:5732 DEBUG: ------ Window Init (Pointer.xml) ------
07:04:38 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
07:04:39 T:5732 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
07:04:39 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
07:04:39 T:5732 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:04:39 T:5732 DEBUG: ------ Window Deinit (Custom_1100_AddonLauncher.xml) ------
07:04:39 T:5732 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
07:04:39 T:5732 DEBUG: ------ Window Init (Home.xml) ------
07:04:39 T:5732 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
07:04:39 T:5732 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
07:04:39 T:5732 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
07:04:39 T:5732 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
07:04:39 T:5732 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
07:04:40 T:5732 DEBUG: ------ Window Init (Pointer.xml) ------
07:04:44 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:44 T:5732 DEBUG: Activating window ID: 10004
07:04:45 T:5732 DEBUG: ------ Window Deinit (Home.xml) ------
07:04:45 T:5732 DEBUG: ------ Window Init (Settings.xml) ------
07:04:46 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:46 T:5732 DEBUG: Activating window ID: 10016
07:04:46 T:5732 DEBUG: ------ Window Deinit (Settings.xml) ------
07:04:46 T:5732 DEBUG: ------ Window Init (SettingsCategory.xml) ------
07:04:56 T:5732 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
07:04:56 T:5732 NOTICE: Disabled debug logging due to GUI setting. Level 0.
Passt dies besser?
Die Addons mussten nicht installiert werden, die sind bei der Installation schon mit dabei ...
Versuche mal die Addons, hier aus dem Forum, ich tippe mal auf einen Fehler im Kodi Git.
Das Deinstallieren der AddOns ist ausgegraut - und wenn ich die AddOns bei der Installation nicht berücksichtige und dann installieren möchte, dann kommt der Fehlerhinweis, dass die Installation fehlgeschlagen ist ...
Dann lösche die Addons doch einfach von Hand, findest du im Kodi installations Ordner und installiere die aus dem Forum mal.
Dann geht es leider auch nicht - auch auf einem 2. Rechner.
Vorgehensweise:
Installation von Kodi 17 beta 4
Versuch, die AddOns zu aktivieren
Löschen der AddOns im Installationsverzeichnis
Versuch, die Addons manuell zu installieren
Das erste AddOn inputstream.mpd-1.2.17 lässt sich nicht installieren, das zweite AddOn inputstream.smoothstream-1.2.3 erwartet eine Abhängigkeit von Version 1.2.14 (vermutlich vom ersten AddOn).
Das Log-File lautet
12:54:03 T:3420 NOTICE: Enabled debug logging due to GUI setting. Level 2.
12:54:03 T:3420 DEBUG: ------ Window Init () ------
12:54:09 T:3420 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
12:54:09 T:3420 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
12:54:09 T:3420 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
12:54:09 T:3420 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:54:09 T:3420 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
12:54:09 T:3420 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
12:54:09 T:3420 DEBUG: ------ Window Init (Settings.xml) ------
12:54:09 T:3420 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
12:54:11 T:3420 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
12:54:11 T:3420 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
12:54:11 T:3420 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
12:54:11 T:3420 DEBUG: ------ Window Deinit (Settings.xml) ------
12:54:11 T:3420 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
12:54:11 T:3420 DEBUG: ------ Window Init (Home.xml) ------
12:54:11 T:3420 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
12:54:14 T:3420 DEBUG: ------ Window Init (Pointer.xml) ------
12:54:16 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:16 T:3420 DEBUG: Activating window ID: 11100
12:54:16 T:3420 DEBUG: ------ Window Deinit (Home.xml) ------
12:54:16 T:3420 DEBUG: ------ Window Init (Custom_1100_AddonLauncher.xml) ------
12:54:16 T:3420 INFO: Loading skin file: Custom_1100_AddonLauncher.xml, load type: KEEP_IN_MEMORY
12:54:16 T:3420 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
12:54:16 T:3420 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
12:54:16 T:3420 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
12:54:16 T:3420 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
12:54:16 T:3420 DEBUG: CDirectoryProvider[addons://outdated/]: refreshing..
12:54:16 T:5956 DEBUG: CAddonMgr::GetAvailableUpdates took 148 ms
12:54:16 T:5956 DEBUG: CAddonMgr::GetAvailableUpdates took 14 ms
12:54:19 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:19 T:3420 DEBUG: Activating window ID: 10040
12:54:19 T:3420 DEBUG: ------ Window Deinit (Custom_1100_AddonLauncher.xml) ------
12:54:19 T:3420 DEBUG: ------ Window Init (AddonBrowser.xml) ------
12:54:19 T:3420 INFO: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
12:54:19 T:3420 DEBUG: CGUIMediaWindow::GetDirectory (addons://)
12:54:19 T:3420 DEBUG: ParentPath = []
12:54:19 T:3420 DEBUG: CAddonMgr::GetAvailableUpdates took 11 ms
12:54:19 T:3228 DEBUG: Thread BackgroundLoader start, auto delete: false
12:54:19 T:3228 DEBUG: Thread BackgroundLoader 3228 terminating
12:54:23 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:23 T:3420 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
12:54:23 T:3420 DEBUG: ------ Window Init (FileBrowser.xml) ------
12:54:25 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:33 T:3420 DEBUG: Previous line repeats 2 times.
12:54:33 T:3420 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
12:54:33 T:3420 DEBUG: CAddonInstaller: installing from zip 'D:\Downloads\inputstream.smoothstream-1.2.3.zip'
12:54:33 T:3420 DEBUG: ADDON: Dll Initializing - InputStream SmoothStreamingMedia
12:54:33 T:3420 DEBUG: SECTION:LoadDLL(zip://D%3A%5CDownloads%http://5Cinputstream.smoothstream-1.2.3.zip/inputstream.smoothstream/inputstream.smoothstream.dll)
12:54:33 T:3420 ERROR: ADDON: Dll InputStream SmoothStreamingMedia - Client returned bad status (6) from Create and is not usable
12:54:33 T:3420 DEBUG: ------ Window Init (DialogConfirm.xml) ------
12:54:33 T:3420 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
12:54:37 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:37 T:3420 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
12:54:37 T:4724 DEBUG: CAddonInstallJob[inputstream.smoothstream]: requires inputstream.mpd version 1.2.14 which is not available
12:54:37 T:4724 ERROR: CAddonInstallJob[inputstream.smoothstream]: Die Abhängigkeit auf inputstream.mpd in Version 1.2.14 konnte nicht aufgelöst werden.
12:54:37 T:3420 DEBUG: CGUIMediaWindow::GetDirectory (addons://)
12:54:37 T:3420 DEBUG: ParentPath = [addons://]
12:54:37 T:3080 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
12:54:37 T:3420 DEBUG: ------ Window Init (DialogNotification.xml) ------
12:54:37 T:3060 DEBUG: Thread BackgroundLoader start, auto delete: false
12:54:37 T:3060 DEBUG: Thread BackgroundLoader 3060 terminating
12:54:43 T:3420 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
12:54:44 T:3420 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:54:45 T:3420 DEBUG: ------ Window Init (Pointer.xml) ------
12:54:48 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:48 T:3420 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
12:54:48 T:3420 DEBUG: ------ Window Init (FileBrowser.xml) ------
12:54:51 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:56 T:3420 DEBUG: Previous line repeats 2 times.
12:54:56 T:3420 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
12:54:56 T:3420 DEBUG: CAddonInstaller: installing from zip 'D:\Downloads\inputstream.mpd-1.2.17.zip'
12:54:56 T:3420 DEBUG: ADDON: Dll Initializing - InputStream MPEG DASH
12:54:56 T:3420 DEBUG: SECTION:LoadDLL(zip://D%3A%5CDownloads%http://5Cinputstream.mpd-1.2.17.zip/inputstream.mpd/inputstream.mpd.dll)
12:54:56 T:3420 ERROR: ADDON: Dll InputStream MPEG DASH - Client returned bad status (6) from Create and is not usable
12:54:56 T:3420 DEBUG: ------ Window Init (DialogConfirm.xml) ------
12:54:59 T:3420 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
12:54:59 T:3420 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
12:54:59 T:4724 DEBUG: Unpacking zip://D%3A%5CDownloads%http://5Cinputstream.mpd-1.2.17.zip/inputstream.mpd/ to C:\Users\diddi\AppData\Roaming\Kodi\temp\98882ec2-24fc-4a3d-876c-0da9520a3b53
12:54:59 T:4724 ERROR: XFILE::CDirectory::Create - Error creating C:\Users\diddi\AppData\Roaming\Kodi\temp\98882ec2-24fc-4a3d-876c-0da9520a3b53\lib
12:54:59 T:4724 ERROR: Failed to unpack archive 'zip://D%3A%5CDownloads%http://5Cinputstream.mpd-1.2.17.zip/inputstream.mpd/' to 'C:\Users\diddi\AppData\Roaming\Kodi\temp\98882ec2-24fc-4a3d-876c-0da9520a3b53'
12:54:59 T:3420 DEBUG: CGUIMediaWindow::GetDirectory (addons://)
12:54:59 T:3420 DEBUG: ParentPath = [addons://]
12:54:59 T:4724 DEBUG: CAddonMgr::GetAvailableUpdates took 14 ms
12:54:59 T:3752 DEBUG: Thread BackgroundLoader start, auto delete: false
12:54:59 T:3752 DEBUG: Thread BackgroundLoader 3752 terminating
12:54:59 T:3420 DEBUG: ------ Window Init (DialogNotification.xml) ------
12:55:04 T:3420 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:55:05 T:3420 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
12:55:09 T:3420 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
12:55:09 T:3420 DEBUG: CInputManager::OnKey: alt-leftalt (0x4f0d4) pressed, action is
12:55:10 T:3420 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
12:55:10 T:3420 DEBUG: CInputManager::OnKey: alt-long-leftalt (0x104f0d4) pressed, action is
12:55:11 T:3420 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
12:55:11 T:3420 DEBUG: CInputManager::OnKey: alt-long-leftalt (0x104f0d4) pressed, action is
12:55:11 T:3420 DEBUG: CWinEventsWin32::WndProcWindow is active
12:55:11 T:3420 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Program Files\SpeedProject\SpeedCommander 16\SpeedCommander.exe
12:55:11 T:3420 NOTICE: Storing total System Uptime
12:55:11 T:3420 NOTICE: Saving settings
12:55:11 T:3420 NOTICE: Saving skin settings
12:55:11 T:3420 NOTICE: stop all
12:55:11 T:5020 DEBUG: Thread JobWorker 5020 terminating (autodelete)
12:55:11 T:1636 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
12:55:11 T:1636 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
12:55:11 T:4724 DEBUG: Thread JobWorker 4724 terminating (autodelete)
12:55:11 T:3080 DEBUG: Thread JobWorker 3080 terminating (autodelete)
12:55:11 T:5956 DEBUG: Thread JobWorker 5956 terminating (autodelete)
12:55:11 T:3420 NOTICE: stop player
12:55:11 T:3420 INFO: stopping PVRManager
12:55:11 T:3420 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
12:55:11 T:3420 NOTICE: ES: Stopping event server
12:55:11 T:3420 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
12:55:11 T:3420 NOTICE: stopping upnp
12:55:11 T:4992 DEBUG: Thread TCPServer 4992 terminating
12:55:11 T:5736 NOTICE: ES: UDP Event server stopped
12:55:11 T:5736 DEBUG: Thread EventServer 5736 terminating
12:55:11 T:5768 DEBUG: Thread PeripEventScanner 5768 terminating
12:55:11 T:2984 DEBUG: Thread PeripBusUSB 2984 terminating
12:55:12 T:3532 DEBUG: Thread PeripBusCEC 3532 terminating
12:55:12 T:2368 DEBUG: Thread PeripBusAddon 2368 terminating
12:55:12 T:3420 NOTICE: clean cached files!
12:55:12 T:3420 DEBUG: ADDON: Stopping service addons.
12:55:12 T:4896 DEBUG: Thread ActiveAE 4896 terminating
12:55:12 T:5728 DEBUG: Thread AESink 5728 terminating
12:55:12 T:3420 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
12:55:12 T:3420 NOTICE: closing down remote control service
12:55:13 T:3936 DEBUG: Thread RemoteControl 3936 terminating
12:55:13 T:3420 NOTICE: stopped
12:55:13 T:3420 NOTICE: destroy
12:55:13 T:3420 NOTICE: unload skin
12:55:13 T:3420 INFO: Unloading old skin ...
12:55:13 T:3420 DEBUG: ------ Window Deinit () ------
12:55:13 T:3420 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
12:55:13 T:5040 INFO: CPythonInvoker(2, C:\Users\diddi\AppData\Roaming\Kodi\addons\script.cu.lrclyrics\default.py): script successfully run
12:55:13 T:3420 DEBUG: CPythonInvoker(2, C:\Users\diddi\AppData\Roaming\Kodi\addons\script.cu.lrclyrics\default.py): script termination took 68ms
12:55:13 T:5040 INFO: Python script interrupted by user
12:55:13 T:5040 DEBUG: Thread LanguageInvoker 5040 terminating
12:55:13 T:3420 NOTICE: unload sections
12:55:13 T:3420 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:55:13 T:3420 DEBUG: PVRManager - destroyed
12:55:13 T:3420 DEBUG: ActiveAE DSP - destroyed
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E16AF80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0EDBC8D0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E16AE60 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E30DFA8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E3022F0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0EDBCA38 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E30E038 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:3420 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0E16ACF8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
12:55:13 T:1636 DEBUG: Thread Announce 1636 terminating
12:55:13 T:3420 NOTICE: application stopped...
12:55:13 T:3420 DEBUG: SECTION:UnloadDll(special://xbmcbin/libcurl.dll)
Nachtrag:
Ich stelle gerade fest, dass sich das dvbviewer-AddOn ebenfalls nicht aktivieren lässt - es scheint also nicht unbedingt am Input-AddOn zu liegen.
Komisch ist jedoch, dass dies unabhängig auf 2 Rechnern (jeweils Win7, einmal x86, einmal x64) nicht funktioniert.
Irgendwie scheine ich kein Glück mit Kodi 17 zu haben ...
@diddi8
Gleiches bei mir. Hab mir damit die komplette Kodi-Installation geschrottet Fing alles damit an, dass ich ein aktuelles Insputstream Addon für das 7TV Addon brauchte.
Kodi läuft bei mir auf nem Win10 HTPC auf AMD-Basis.
Ich probiere heute Abend einfach mal ein paar Nightlies aus. Hoffe nicht, dass sich da irgendwas in die Registry geschlichen hat, was ich nicht mehr los werde.
Schöne Grüße
basediver
Hatte ich ja heute morgen schon geschrieben, da wird wohl etwas aus dem Git geflogen sein, was nicht sollte.
Eben dies ist nicht komisch, bestätigt einfach nur die Annahme eines Bugs, jetzt ist es an dir einen
Bugreport dort zu starten, falls du Lust hast.
Jep, dies war der Grund.
Mit der Beta 3 von Kodi 17 geht es wie gewünscht ...
Danke.
Welche Anleitung nimmt man für Odroid C2 ?
Hi, ich weiß solche Fragen nerven meistens... aber wenn ihr es hier nicht wisst wer dann?
Ich versuche das Amazon Prime AddOn auf meiner QNAP (also Linux) zum laufen zu bringen... das Inputstream Add-On habe ich natürlich installiert und den Decrypter Pfad in den Settings auf den Lib Ordner zeigen lassen... wenn ich den ersten Post richtig verstehe dann sollten dort ja die decrypter files drinnen liegen?
Im Amazon Prime AddOn habe ich gesagt er soll Inputstream verwenden....
Wenn ich übers AddOn dann irgendeinen Amazon Film/Serie starten will, lädt Kodi einige Sekunden und zeigt dann an das er die Datei nicht erstellen/finden könnte oder so...
hast du widevine laut Anleitung von mariol installiert?
bin da auch schon mal drübergestolpert.
LG
Xav
LG
Xav
Danke... hab mir die Anleitungen nochmals durchgelesen... konnte ich zwar so direkt nicht verwenden auf der Qnap aber ich habe im Prinzip verstanden um was es geht...
im Prinzip habe ich über Putty auf der QNAP nun folgendes ausgeführt:
ln -s /share/CACHEDEV1_DATA/.qpkg/Chrome/opt/google/chrome/libwidevinecdm.so /share/CACHEDEV1_DATA/.qpkg/mykodi17/homes/newkodi17/.kodi/addons/inputstream.mpd/lib/
das verlinkt die libwidevinecdm.so aus dem Chrome Browser der Qnap ins Kodi Verzeichnis auf der Qnap...
ein erster Test hat schon funtioniert... bei einem 2ten Film (transcendence) habe ich zwar Ton gehört aber kein Bild gehabt..bzw. die Zeit anzeige war irgendwo bei 500min... keine Ahnung...
edit: habjetzt nochmal mit ein paar Serien probiert.. selbes Problem... Zeit teilweise irgendwo, aber auch gehabt normal... kein Bild, aber Ton.. bzw. wenn ich auf Videomodus gehe dann sehe ich nur einen Mauszeiger der hängen bleibt...
edit2: ok wenn ich es richtig im amazon plugin thread verstanden habe ist das Problem mit der Zeit/Bild bekannt.. und liegt daran das bestimmte Videos auf Amazon ein neues DRM Format verwenden mit dem das Plugin bzw. irgend etwas noch nicht umgehen kann... schade...
super das es geklappt hat,
ja mit dem Problem Ton aber kein Bild ist es leider gerade so.
LG
Xav
Guten Morgen, auf der Installationsseite [Kodi 17] Inputstream AddOns fuer den Kodi [17] VideoPlayer, aktuelle Git builds < Update 18.10
steht das "Ab der AddOn Version, 1.2.0, ist der Decrypter ( libssd_wv .so/.dll/.dylib) auf die aktuelle Version zu updaten."
Meine Frage is nun wie geht denn das?
Weil ich bekomme irgendwie Magine TV nicht zum laufen udn vermute erstmal das es daran liegen kann.
Hab ein Raspberry pi 3 mit Kodi 17 und LibreELEC beta 8
Danke ihr macht echt ne Klasse arbeit hier, Amazon läuft sonnst bis auf ein Paar Filme vor die DRM Fehlermeldung kommt super.
Mit der Problematik des Magine TV hat sich erledigt, hab ein Update gemacht nun läuft die Geschichte.
Guten Morgen (deutsche Zeit),
aus konzeptionellen Gründen bin ich gerade dabei, die inputstream.xy Addons aus meinem repo in ein einzelnes binary addon zu überführen.
Es wird in Zukunft genau ein Addon geben (inputstream.adaptive), welches mpd / smoothstream, später hls und netflix manifeste interpretieren kann.
Addonseitig muss darauf reagiert werden, indem die ListItem properties auf das neue Addon angepasst werden.
Neben den gewohnten properties (license_data / license_key / license_type gibt es nun auch noch manifest_type)
Damit ihr (Addon-Entwickler @jojo, @Sandmann, @LORE, @membrane) frühzeitig eure Addons fit machen könnt, bitte ich euch, sobald wie möglich ZUSÄTZLICH zu den inputstream.mpd.XY properties die entsprechenden inputstream.adaptive.XY properties zu setzen.
Beispiel:
listItem.SetProperty("inputstream.mpd.license_type", "com.widevine.alpha")
Neu:
listItem.SetProperty("inputstream.adaptive.license_type", "com.widevine.alpha")
Zusätzlich bitte dann noch die Angabe, um was für ein Manifest es sich handelt:
listItem.SetProperty("inputstream.adaptive.manifest_type", "[mpd, ism]")
Bei Fragen bitte fragen....
@peak ich vermute mal man kann die neuen Proerties mit setzen zu den alten oder. Dan dürfte es jetzt noch gehen. Und später auch oder?
@LORE ja, du kannst die parallel setzen. leider hab ich einen Parameter vergessen: inputstreamaddon=xy, mit dem kodi gesagt wird, welches addon genommen werden soll.
Entweder es muss in python eine Abfrage rein, bei der kodi gefragt wird, was gerade aktiv ist, oder in kodi muss etwas rein, dass du mehrere addons angeben kannst, und kodi das erste installierte / aktivierte nimmt.
