OpenELEC 5.0.5, RPi2, LCD hd44780 Probleme
  • hallo zusammen,
    ich nutze seit kurzem den RPi2 mit OpenELEC (official) Version 5.0.5 Kernel 3.18.8 Kodi 14.2
    und wollte an diesem ein HD44780 LCD anschließen,
    Pin Belegung mehrfach überprüft
    Im Anschluss der Auszug aus meiner LCDd.conf
    LCDd.conf unter „/storage/.config/LCDd.conf“
    Hd44780 treiber unter „/storage/.config/raspdrivers“
    LCDd unter „storage/.confid/LCDd“
    LCD.xml unter /storage/.kodi/userdata/LCD.xml
    [cbox]
    # Where can we find the driver modules ?
    # IMPORTANT: Make sure to change this setting to reflect your
    # specific setup! Otherwise LCDd won't be able to find
    # the driver modules and will thus not be able to
    # function properly.
    # NOTE: Always place a slash as last character !
    DriverPath=/storage/.config/raspdrivers/
    # Tells the server to load the given drivers. Multiple lines can be given.
    # The name of the driver is case sensitive and determines the section
    # where to look for further configuration options of the specific driver
    # as well as the name of the dynamic driver module to load at runtime.
    # The latter one can be changed by giving a File= directive in the
    # driver specific section.
    # The following drivers are supported:
    # bayrad, CFontz, CFontz633, CFontzPacket, curses, CwLnx, ea65,
    # EyeboxOne, g15, glcdlib, glk, hd44780, icp_a106, imon, imonlcd,
    # IOWarrior, irman, joy, lb216, lcdm001, lcterm, lirc, lis, MD8800,
    # mdm166a, ms6931, mtc_s16209x, MtxOrb, mx5000, NoritakeVFD, picolcd,
    # pyramid, sed1330, sed1520, serialPOS, serialVFD, shuttleVFD, sli,
    # stv5730, svga, t6963, text, tyan, ula200, xosd
    Driver=hd44780
    # Tells the driver to bind to the given interface
    Bind=127.0.0.1
    # Listen on this specified port; defaults to 13666.
    Port=13666
    ## Hitachi HD44780 driver ##
    [hd44780]
    # Select what type of connection. See documentation for types.
    ConnectionType=rpi
    D7=12
    D6=23
    D5=24
    D4=25
    RS=7
    EN=8
    # Port where the LPT is. Usual value are: 0x278, 0x378 and 0x3BC
    Port=0x378
    # Specifies the size of the LCD.
    # In case of multiple combined displays, this should be the total size.
    Size=20x4
    [/cbox]
    Das Display macht auch irgendetwas als würde es angesprochen (flackert
    leicht beim Ordnerwechsel Video-->Musik-->LiveTV-->etc.)
    Neuinstallation - schon getestet
    andere SD-Card - schon getestet
    Anderes Netzteil – schon getestet
    Zusätzlicher Wiederstand am LCD – schon getestet
    Anderes LCD – schon getestet
    Nach Anleitung dieser Seite – schon getestet http://openelec.tv/forum/124-rasp…780-lcd-display
    Nach Anleitung dieser Seite auch - schon getestet http://www.sknorrell.de/blog/lcd-displ…r-raspberry-pi/
    nur ändert sich an meinem Problem leider nichts.
    Vielleicht kann mir hier einer weiterhelfen
    Mfg Alex
