tvheadend absturzt nach aufwachen aus dem Standby(Bereitschaft)
  • Moin,
    also ich habe das Problem das wenn Kodi wieder aus dem Standby aufwache, es zu 80 % Abstürzt.
    Nach den logs müsste es der tvheadend sein der die Grätsche macht, ich kann aber nicht sagen warum.
    Ich benutze Openelec 5.0.2 und die neuste tvheadend Version.
    Kann mir vielleicht einer einen tipp geben ????
    hier die logs:
    20:27:20 T:140151208531712 NOTICE: Previous line repeats 1 times.
    20:27:20 T:140151208531712 NOTICE: StorageServer Module loaded RUN
    20:27:20 T:140151208531712 NOTICE: StorageClient-2.5.4 Starting server
    20:27:21 T:140151795726080 NOTICE: Thread JobWorker start, auto delete: true
    20:27:21 T:140151225317120 NOTICE: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - connection opened to 'HTS Tvheadend 3.9.2496~gd386ed0', protocol v19 (timeshift enabled)
    20:27:22 T:140149883139840 NOTICE: Thread JobWorker start, auto delete: true
    20:27:22 T:140149874747136 NOTICE: Thread PVRGUIInfo start, auto delete: false
    20:27:22 T:140151200139008 NOTICE: script.tv.show.next.aired: ### exiting this duplicate background-proc (skin vs service)
    20:27:23 T:140151200139008 NOTICE: Thread EPGUpdater start, auto delete: false
    20:27:23 T:140151778940672 NOTICE: Start - EPG thread started
    20:27:23 T:140150269007616 NOTICE: Thread JobWorker start, auto delete: true
    20:56:07 T:140151183353600 NOTICE: ES: Client from 192.168.178.48 timed out
    20:59:30 T:140150805960448 NOTICE: Thread LanguageInvoker start, auto delete: false
    20:59:30 T:140150805960448 NOTICE: -->Python Interpreter Initialized<--
    21:31:10 T:140150805960448 NOTICE: Thread LanguageInvoker start, auto delete: false
    21:31:10 T:140150805960448 NOTICE: -->Python Interpreter Initialized<--
    21:35:32 T:140152321718144 NOTICE: OnSleep: Running sleep jobs
    21:35:32 T:140152321718144 NOTICE: OnSleep: Stopping lirc
    21:35:33 T:140150229583616 ERROR: AddOnLog: Tvheadend HTSP Client: ReadMessage - failed to read packet size (Connection reset by peer)
    21:35:33 T:140150229583616 ERROR: AddOnLog: Tvheadend HTSP Client: connection dropped, trying to restore
    21:35:33 T:140150229583616 ERROR: AddOnLog: Tvheadend HTSP Client: ReadMessage - not connected
    21:35:33 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: ReadMessage - failed to read packet size (Connection reset by peer)
    21:35:33 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - failed get a reply after the greeting
    21:35:33 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: Connect - failed to read greeting from the backend
    21:35:33 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: TransmitMessage - failed to write packet (Connection refused)
    21:35:33 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - failed to transmit greeting
    21:36:02 T:140152241420032 NOTICE: m_displayName : HD-Audio Generic
    21:36:02 T:140152241420032 NOTICE: m_displayNameExtra: ALC892 Digital S/PDIF
    21:36:02 T:140152241420032 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
    21:36:02 T:140152241420032 NOTICE: m_channels : FL,FR
    21:36:02 T:140152241420032 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
    21:36:02 T:140152241420032 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
    21:36:02 T:140150766290688 NOTICE: Thread LanguageInvoker start, auto delete: false
    21:36:02 T:140150766290688 NOTICE: -->Python Interpreter Initialized<--
    21:36:13 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: ReadMessage - failed to read packet (Connection refused)
    21:36:13 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - failed get a reply after the greeting
    21:36:13 T:140150805960448 ERROR: AddOnLog: Tvheadend HTSP Client: Connect - failed to read greeting from the backend
    21:36:13 T:140150805960448 NOTICE: AddOnLog: Tvheadend HTSP Client: CHTSPConnection - SendGreeting - connection opened to 'HTS Tvheadend 3.9.2496~gd386ed0', protocol v19
    21:36:33 T:140151183353600 NOTICE: ES: Client from 127.0.0.1 timed out
  • Du kannst ja mal probieren, von außen auf den TVH-Server zuzugreifen.
    Ich vermute, dass das USB-Device abgemeldet wird (S3 oder S4) und beim hochfahren nicht wieder neu initialisiert.
    Dann findet TVH kein Device und verweigert entsprechend die Zusammenarbeit.
    Ist aber nur ne Vermutung. Aus dem [definition='1','0']log[/definition] kann man das nicht ablesen.
  • Ich kann sagen das TVH Standby, Ruhezustand etc. nicht sonderlich mag.
    Hatte das gleiche Problem, nach dem aufwecken hat TVH die Grätsche gemacht.
    Ich konnte das Problem lösen in dem ich unter "/etc/pm/sleep.d" ein Skript hinterlegt habe welches TVHeadend vor dem Sleep stoppt und beim aufwecken wieder weckt.
    Alle Skripte in diesem Ordner werden beim einschlafen abgearbeitet.
    Inwieweit openelec das unterstützt (bzw in der Richtung beschnitten ist) kann ich nicht sagen..
    Meine Hardware
    [contentbox]TV-Server/NAS:
    Gigabyte GA-B85M-D2V | Intel G1840 | 4GB RAM | 1x SSD 120GB System | 1x SSD 30GB Kodi Thumbs & mySQL | 3x HDD (9TB) |
    DD Cine S2 6.5 4Tuner | OMV 2.x[/contentbox][contentbox]Backup-Server: AMD Athlon 64 X2 | 1GB RAM | 5,5 TB | OMV 2.x[/contentbox]
    [contentbox] HTPC | Asrock Q1900-ITX | 4GB RAM | 120Gb Samsung SSD | OpenELEC 5.0.8
    2x RasPi 1 | OpenELEC 5.0.8
    RasPi 2 | OpenELEC 5.0.8
    MacBook Pro | Kodi 14.2[/contentbox]
