ich bekomme keine Audio Ausgabe über Line Out (interne auf dem Mainboard) wenn ich eine VDR-Aufnahme abspiele.
Im XBMC habe ich bei den Audio Einstellungen: "Internes Audio Analog Stereo (Line Out)" eingestellt.
Wenn ich die VDR-Aufnahme über Kaffeine abspiele, funktioniert die Tonausgabe.
OS = openSUSE 13.1 64 Bit
XBMC 13.1
Auszug aus xbmc.[definition='1','0']log[/definition]
13:43:37 T:140023980845248 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:43:37 T:140023980845248 NOTICE: -----------------------------------------------------------------------
13:43:37 T:140023980845248 NOTICE: Starting XBMC (13.1 Git:Unknown). Platform: x86 Linux 64-bit
13:43:37 T:140023980845248 NOTICE: Using Release XBMC x64 build, compiled Aug 23 2014 by GCC 4.8.1 for x86 Linux 64-bit 3.11.0
13:43:37 T:140023980845248 NOTICE: Running on Linux 64-bit (openSUSE 13.1 (Bottle) (x86_64), 3.11.10-21-desktop x86_64)
13:43:37 T:140023980845248 NOTICE: Host CPU: AMD Athlon(tm) 64 Processor 3800+, 1 core available
13:43:37 T:140023980845248 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
13:43:37 T:140023980845248 NOTICE: special://xbmcbin/ is mapped to: /usr/lib64/xbmc
13:43:37 T:140023980845248 NOTICE: special://masterprofile/ is mapped to: /home/juergen/.xbmc/userdata
13:43:37 T:140023980845248 NOTICE: special://home/ is mapped to: /home/juergen/.xbmc
13:43:37 T:140023980845248 NOTICE: special://temp/ is mapped to: /home/juergen/.xbmc/temp
13:43:37 T:140023980845248 NOTICE: The executable running is: /usr/lib64/xbmc/xbmc.bin
13:43:37 T:140023980845248 NOTICE: Local hostname: openSUSE131
13:43:37 T:140023980845248 NOTICE: Log File is located: /home/juergen/.xbmc/temp/xbmc.[definition='1','0']log[/definition]
13:43:37 T:140023980845248 NOTICE: load settings...
13:43:37 T:140023980845248 NOTICE: Found 1 Lists of Devices
13:43:37 T:140023980845248 NOTICE: Enumerated PULSE devices:
13:43:37 T:140023980845248 NOTICE: Device 1
13:43:37 T:140023980845248 NOTICE: m_deviceName : Default
13:43:37 T:140023980845248 NOTICE: m_displayName : Default
13:43:37 T:140023980845248 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
13:43:37 T:140023980845248 NOTICE: m_deviceType : AE_DEVTYPE_PCM
13:43:37 T:140023980845248 NOTICE: m_channels : FL,FR
13:43:37 T:140023980845248 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
13:43:37 T:140023980845248 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S16NE,AE_FMT_S24LE3,AE_FMT_S24BE3,AE_FMT_S24NE3,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S24NE4,AE_FMT_S32BE,AE_FMT_S32LE,AE_FMT_S32NE,AE_FMT_FLOAT
13:43:37 T:140023980845248 NOTICE: Device 2
13:43:37 T:140023980845248 NOTICE: m_deviceName : alsa_output.pci-0000_00_05.0.analog-stereo
13:43:37 T:140023980845248 NOTICE: m_displayName : Internes Audio Analog Stereo
13:43:37 T:140023980845248 NOTICE: m_displayNameExtra: Line Out (PULSEAUDIO)
13:43:37 T:140023980845248 NOTICE: Device 3
13:43:37 T:140023980845248 NOTICE: m_deviceName : alsa_output.pci-0000_02_00.1.hdmi-stereo-extra3
13:43:37 T:140023980845248 NOTICE: m_displayName : High Definition Audio Controller Digital Stereo (HDMI)
13:43:37 T:140023980845248 NOTICE: m_displayNameExtra: HDMI / DisplayPort 4 (PULSEAUDIO)
13:43:37 T:140023980845248 NOTICE: No settings file to load (special://xbmc/system/[definition='2','1']advancedsettings[/definition].xml)
13:43:37 T:140023980845248 NOTICE: Loaded settings file from special://profile/[definition='2','1']advancedsettings[/definition].xml
13:43:37 T:140023980845248 NOTICE: Contents of special://profile/[definition='2','1']advancedsettings[/definition].xml are...
<loglevel>3</loglevel>
<remotedelay>20</remotedelay>
<remoterepeat>2000</remoterepeat>
13:43:37 T:140023980845248 NOTICE: Log level changed to 2
13:43:37 T:140023980845248 NOTICE: Default DVD Player: dvdplayer
13:43:37 T:140023980845248 NOTICE: Default Video Player: dvdplayer
13:43:37 T:140023980845248 NOTICE: Default Audio Player: paplayer
13:43:37 T:140023980845248 NOTICE: Disabled debug logging due to GUI setting. Level 1.
13:43:37 T:140023980845248 NOTICE: Log level changed to 1
13:43:37 T:140023980845248 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
Alles anzeigen
MfG
Juergen B.
