![](https://www.kodinerds.net/wcf/images/avatars/d8/617-d8861845167334d83831121a8fc3a69347c723a1.jpg)
Diskussionsthema zum How to: Soundgraph iMON VDF Display/IR mit XBMCbuntu 12.2
blauesgruen -
8. April 2014 um 18:39 -
root@Fireball-HTPC:~# sudo service LCDd start
Starting LCDd: LCDd.
root@Fireball-HTPC:~# ps -ef | grep -i lcd
root 2457 2368 0 20:11 pts/0 00:00:00 grep --color=auto -i lcd
root@Fireball-HTPC:~# -
Bus 004 Device 003: ID 15c2:0044 SoundGraph Inc.
Hast du die addons installiert?
-mobile
Meinst du das in KODI ?
mfg
Ja
-mobile
Ja ist instaliert
Habe jetzt mal diese Sachen ausgeführt (mit anpassung auf imonLCD)
kodibuntu-14.0~helix_amd64.iso installiert
sudo apt-get update
sudo apt-get upgradesudo apt-get install git-core build-essential lcdproc
sudo apt-get install libusb-dev
wget http://repository.timesys.com/buildsources/l…d-0.2.16.tar.gz
tar xzvf libhid-0.2.16.tar.gz
cd libhid-0.2.16
./configure --disable-werror
make
sudo make installwget http://sourceforge.net/projects/lcdpr…oc-0.5.7.tar.gz
tar xzvf lcdproc-0.5.7.tar.gz
cd lcdproc-0.5.7
./configure --enable-drivers=mdm166a
cd server/drivers
make
sudo cp mdm166a.so /usr/lib/x86_64-linux-gnu/lcdproc/sudo apt-get build-dep lcdproc
sudo /etc/init.d/LCDd restart
sudo lcdprocJetzt bekomme ich diese Fehlermeldung
Error connecting to LCD server localhost on port 13666.
Check to see that the server is running and operating normally.mfg
Sep 30 12:36:02 Fireball-HTPC LCDd: Critical error while initializing, abort.
Sep 30 11:53:28 Fireball-HTPC console-kit-daemon[1364]: GLib-CRITICAL: Source ID 15 was not found when attempting to remove it
Sep 30 13:16:59 Fireball-HTPC console-kit-daemon[1364]: GLib-CRITICAL: Source ID 33 was not found when attempting to remove it
Sep 30 13:17:02 Fireball-HTPC CRON[15185]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 30 13:18:12 Fireball-HTPC LCDd: imonlcd: ERROR opening /dev/lcd0 (No such file or directory).
Sep 30 13:18:12 Fireball-HTPC LCDd: imonlcd: Did you load the iMON kernel module?
Sep 30 13:18:12 Fireball-HTPC LCDd: Driver [imonlcd] init failed, return code -1
Sep 30 13:18:12 Fireball-HTPC LCDd: Could not load driver imonlcd
Sep 30 13:18:12 Fireball-HTPC LCDd: There is no output driver
Sep 30 13:18:12 Fireball-HTPC LCDd: Critical error while initializing, abort. -
sieht ja wie hier aus:
http://ubuntuforums.org/archive/index.php/t-1049305.html -
Hallo
Habe es gerade hinbekommen.
LCDd.conf
driver=imon
Device=/dev/lcd1
jetzt gehts endlich
Vielen dank für die Tolle hilfe echt klasse von euch
mfg
Das Display vom S10V ließ sich bei mir eigentlich strait forward einrichten und läuft soweit auch prima.
Einzig die fehlenden Umlaute stören noch etwas.
Hat zufällig noch jemand 'ne Idee, wie man das hinbekommt?
Die Zeichensätze im LCDproc hab* ich schon durchprobiert, aber das bringt keine Änderung.Besten Dank
Lena
Edit: Umlaute gelöst - siehe hier
So, nachdem ich mich nach einigen Updates geraume Zeit über die fehlenden Umlaute geärgert habe, habe ich mich nun noch einmal mit dem Thema rumgeschlagen - mit Erfolg
Eigentlich ganz einfach:
1.: Die derzeit aktuelle Version 5.9 von https://github.com/lcdproc/lcdpro…oc-0.5.9.tar.gz laden und entpacken.
2.:Code./configure --prefix=/usr --sysconfdir=/etc --libdir=/usr/lib/x86_64-linux-gnu/ --enable-drivers=imon --enable-extra-charmaps
--libdir natürlich auf die eigene Architektur anpassen
das entscheidende ist hier der Parameter --enable-extra-charmaps
3.: das übliche make und sudo make install
4.: in der /etc/LCDd.conf (gekürzt)Code
Alles anzeigen[server] DriverPath=/usr/lib/x86_64-linux-gnu/lcdproc/ Driver=imon Bind=127.0.0.1 Port=13666 ReportToSyslog=yes User=nobody Hello="Moin, moin" GoodBye = "see you later" GoodBye = " Alligator!" WaitTime=0 ServerScreen=off Backlight=on Heartbeat=off [menu] ### Driver sections are below this line, in alphabetical order ### ## Soundgraph/Ahanix/Silverstone/Uneed/Accent iMON driver ## [imon] # select the device to use Device=/dev/lcd1 # display dimensions Size=16x2 # Character map to to map ISO-8859-1 to the displays character set. # [default: none; legal: none, hd44780_euro, upd16314, hd44780_koi8_r, # hd44780_cp1251, hd44780_8859_5 ] (upd16314, hd44780_koi8_r, # hd44780_cp1251, hd44780_8859_5 are possible if compiled with additional # charmaps) # CharMap=hd44780_euro CharMap=upd16314
Zeile 35 bringt den Durchbruch
5.: zum Schluss noch in den Einstellungen des LCDproc Addons die alternativen Zeichensätze abschalten und - feddich!Ich hoffe das klappt so auch bei anderen - viel Spaß!
