super gemacht bisher :). meiner meinung nach sollte nur beim Live TV die Info der laufenden Sendung unter dem Sender namen stehen und nicht drüber in einem extra kasten
[WIP] refred - reFocus revised - mag wer... testen? ^^
sualfred -
29. April 2014 um 14:06 -
Jap, da hast du nicht ganz unrecht. Ich bin noch nicht wirklich zufrieden mit den OSD. Hab das aber erstmal nach hinten geschoben bis ich eine Eingebung hab.
Update
17.05.14
- TV Logo crop issue should be fixed @ Schumi2004
- Added new viewtype called BottomSlide for TV shows, seasons and movies
- Added fallback discart for movies (combination of fanart, studio flag, available clearlogo and if clearlogo isn't available, the title) - used in Left/RightList, BottomSlide, widget panel
- Added discart support for tvshows/seasons (combination of fanart, studio flag, available clearlogo and if clearlogo isn't available, the title) - used in Left/RightList, BottomSlide
- Changed some things in the in progress widget tab (added additional list item information, rearranged some things)
- Fixed a widgets logic
- Fixed a lot of small issues and some cleanupFor those guys, who want to change the color theme:
Go to the folder "defaults" inside the skin and create a copy of defaults.xml and rename it to whatever you want (if you want a pink theme, you can name it "ultraugly.xml" for example ^^). Then, just open it in a texteditor and change/play around with the attributes.
The colors are defined by hex code. Here is a example:
#FF000000
- The first two positions (FF) are the transparency. In this case the color has no transparency (FF=100% visible, 00 = 0%).
- The next 6 positions are the hex value of red, green, blue mix. You can use a colorpicker for it (http://www.colorpicker.com/) and simply add the transparency level you want.
If you are done, start your XBMC and go to the vizualisation settings. You can choose a color theme now.
Hint: If you don't want to restart your XBMC each time you play around with the color settings, enable the reload button of the skin and simply reload the skin to apply your changes. -
Ok, so we have to talk now in english?
Gesendet von meinem One X mit Tapatalk
Macht der Gewohnheit. Durch mein Job in der IT Sercurity bin ich gewzungen mich täglich hauptsächlich auf Englisch zu unterhalten. Inzwischen färbt das auf alles ab und selbst meine Spezis schaun manchmal bläd wenn ich nen Hochdeutsch/Bayrisch/Denglisch Mix von mir geb
Hinzu kommt die Faulheit. EN dürfte jeder können und langt für changelogs
Lazy as hell.
Kann man die vorschaubilder entfernen? Also die bei Live TV, Videos, Bilder etc...
Hallo sualfred,
wir hatten kurz Kontakt über das xbmc forum, bzgl. der Artistslideshow und den vielen Ausrufezeichen. Du erinnerst Dich vielleicht.
Da meine Englisch Kentnisse leider nicht besser werden, schreibe ich Dich hier mal kurz an.Also, Artistslideshow funktioniert mittlerweile prächtig (Update auf neue Version) und ich finde, dass Dein Skin von mal zu mal besser und ausgereifter wird.
Hat meinen ehemaligen DailyDriver ACE seit langem abgelöst.
Danke nochmal für die viele Arbeit, die Du da rein steckst. Kann man dir irgendwo ein Bier kaufen oder eine kleine Aufmerksamkeit für die viele Zeit, die Du investierst zu Gute kommen lassen ???Und dann hätte ich auch noch eine kleine Bitte, bzw. einen Vorschlag.
Ich habe mir mal den BOX Skin im Original XBMC Forum angeschaut. Auch ein nettes Dingen, aber was mich geflasht hat, ist die Visualisierung bei der Musikwiedergabe. Da "fliegt" der Musiktitel und die Abspielzeit durch den Bildschirm. Sieht einfach geil aus.
Besteht eine Möglichkeit, dass Du das mit in Deinen Skin implementierst ?? Das wäre der Hammer, natürlich nur, wenn es keine Probleme mit den Machern des BoX Skin gibt.
Vielleicht setzt Du es ja mit auf Deine "to Do" Liste, von mir auch auch nach unten, aber geil wäre es schon.
Schönen Sonntag noch,
Gruß,
Christian -
Komme gerade aus meinem wohlverdienten Urlaub und siehe da, du hast die Musikvisualisierung Motorola eingebaut!
Vielen, vielen Dank!!!
Schönen Sonntag noch und nochmal Danke für Deine viele Arbeit und Mühe, die du in diesen Skin steckst.
Gruß,
Christian -
Moin, wird es eine Version für helix geben? finde diesen Skin sehr angenehm, und würde ihn gerne
unter Kodi nutzen.... -
Sry für die späte Antwort.
Aber ich hab die Arbeiten an dem Skin eingestellt vor Monaten. Ich konnt ihn einfach selber nicht mehr sehen und es hat zuviel Freizeit gefressen.
Nutze auch selber bereits die Kodi 15 Nightlies aus Feature-Gründen und neeee da läufts mir jetzt schon eiskalt den Buckel runter wenn ich das Ding noch updaten müssteZuviel Ich-lern-gerade-erst-das-XBMC-Skinning Müll, den ich da drin geschrieben habe im Skin.
Bin selber auf Bello gewechselt und hab dort nen kleinen Mod dazu gemacht. Aber tu dir kein Zwang an. Bis auf den PVR Part ist alles relativ schnell auf Kodi geportet. Selbst ist der Mann
Vielleicht kann sich ein Skinner ja mal erbahmen, ist wirkich ein netter Skin.
Hatte ihn gern unter Frodo genutzt....
Mir fehlt leider die ErfahrungGruß
