Hallo Zusammen,
ich möchte gern in XBMC, PowerDVD12 einbinden. Nach dem HowTo von mad-max (http://myxbmc.bplaced.net/blog/?p=266)
habe ich es bereits versucht. Doch leider startet der Film nicht, wenn ich in XBMC auf Disk Spielen klicke.
Mein System:
Intel I3 3225
Asus P8H77-mPro
8GB Ram
Win pro 8 64 bit
XBMC12
Konfiguration:
Blu-ray Laufwerk ist D:
PlayBDMV.bat
ZitatAlles anzeigen
Echo off
rem you can
place your PlayBDMV file in \Roaming\XBMC\userdata\
set pth=%1
set
pth=%pth:BDMV\index.bdmv=%
"C:\Program
Files (x86)\CyberLink\PowerDVD12\PowerDVD12.exe" %pth% exit
PlayDisc.bat
Echo off
rem you can
place your PlayDisc file in \Roaming\XBMC\userdata\
"C:\Program
Files (x86)\CyberLink\PowerDVD12\PowerDVD12.exe" D:
Playercorefactory.xml
ZitatAlles anzeigen
<playercorefactory>
<players>
<player name="ISO_Player"
type="ExternalPlayer" audio="false"
video="true">
<filename>C:\Users\USERNAME\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
</player>
<player
name="BDMV_Player" type="ExternalPlayer"
audio="false" video="true">
<filename>C:\Users\USERNAME\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
</player>
<player
name="Disc_Player" type="ExternalPlayer"
<filename>C:\Users\USERNAME\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
</players>
<rules
action="prepend">
<!-- Bluray
ISO -->
<rule
filenames="iso" filetypes="iso" player="ISO_Player"/>
<!-- Bluray
BDMV -->
<rule
filenames="bdmv" filetypes="bdmv"
player="BDMV_Player"/>
<!-- Bluray
Disc -->
<rule
filenames="BD" name="D:\\.*" filetypes="bdmv"
player="Disc_Player"/>
</rules>
</playercorefactory>
PlayISO.bat
ZitatAlles anzeigenEcho off
rem you can
place your PlayISO file in \Roaming\XBMC\userdata\
rem you
need to put the correct VCDMount drive letter in the command below
"C:\Program
Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program
Files (x86)\CyberLink\PowerDVD12\PowerDVD12.exe" G:
Für Eure Hilfe besten Dank im Voraus!
Baudi
