Hallo Leute,
ich wollte eben einen Film über meine Stereoanlage (Optisches Kabel) mit 5.1 anschauen. Leider bekomme ich keinen Ton. Was mache ich falsch? Hier meine asound.conf:
pcm.!default { type plug slave { pcm "both" }}pcm.both { type route slave { pcm multi channels 4 } ttable.0.0 1.0 ttable.1.1 1.0 ttable.0.2 1.0 ttable.1.3 1.0}pcm.multi { type multi slaves.a { pcm "tv" channels 2 } slaves.b { pcm "dmixrec" channels 2 } bindings.0.slave a bindings.0.channel 0 bindings.1.slave a bindings.1.channel 1 bindings.2.slave b bindings.2.channel 0 bindings.3.slave b bindings.3.channel 1}pcm.dmixrec { type dmix ipc_key 1024 slave { pcm "receiver" period_time 0 period_size 1024 buffer_size 8192 rate 48000 } bindings { 0 0 1 1 }}pcm.tv { type hw card 0 device 3 channels 2}pcm.receiver { type hw card 0 device 1 channels 2}
aplay -l gibt folgendes her:
root ~/.config # aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC889 Analog [ALC889 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC889 Digital [ALC889 Digital]
Subdevices: 1/1
card 0: Intel [HDA Intel], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
card 0: Intel [HDA Intel], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
und aplay -L sagt folgendes:
root ~/.config # aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=Intel
HDA Intel, ALC889 Analog
Default Audio Device
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, ALC889 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=Intel,DEV=0
HDA Intel, HDMI 0
HDMI Audio Output
hdmi:CARD=Intel,DEV=1
HDA Intel, HDMI 1
HDMI Audio Output
was mache ich falsch? Kann mir vlt. jemand helfen? Danke
