Hi,
ich habe Probleme damit ein paar mkv's abzuspielen. Dauer 1h, Größe etwa 7GB.
Das Profil ist High@4.1
[expander]
Format : Matroska
Format version : Version 2
File size : 7.03 GiB
Duration : 1h 1mn
Overall bit rate mode : Variable
Overall bit rate : 16.3 Mbps
Movie name : Game of Thrones (2011) - Ep 01
Encoded date : UTC 2012-03-06 15:54:26
Writing application : mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 10@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 1mn
Bit rate : 14.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.289
Stream size : 6.19 GiB (88%)
Writing library : x264 core
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 1mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 665 MiB (9%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 1h 1mn
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Stream size : 42.3 MiB (1%)
Title : commentary
Writing library : libVorbis 1.1.1/1.1.2 (UTC 2005-03-04)
Language : English
Default : No
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
Text #2
Format : ASS
Language : Dutch
Default : No
Forced : No
Text #3
Format : ASS
Language : Swedish
Default : No
Forced : No
Text #4
Format : ASS
Language : Finnish
Default : No
Forced : No
Text #5
Format : ASS
Language : Norwegian
Default : No
Forced : No
Text #6
Format : ASS
Language : Danish
Default : No
Forced : No
Text #7
Format : ASS
Language : Romanian
Default : No
Forced : No
Text #8
Format : ASS
Language : French
Default : No
Forced : No
Text #9
Format : ASS
Language : Portuguese
Default : No
Forced : No
Text #10
Format : ASS
Language : Spanish
Default : No
Forced : No
Text #11
Format : ASS
Language : Polish
Default : No
Forced : No
[/expander]
Hardware Acceleration (VDPAU,VAAPI) ist aktiviert, ebenso wie Adjust display refresh ratio to match video.
XBMC läuft als XBMCBuntu (XBMCFreak LiveCD v5) in der finalen Eden auf einem Zotac AD10 mit 4GB Ram.
Die Dateien liegen auf einer direkt angeschlossenen Festplatte, also kein streaming!
Trotzdem habe ich jede menge drops und bild und ton sind nicht synchron, das bild scheint sehr langsam zu sein, zu stocken und teilweise schlechte qualität zu haben!
Woran kann das liegen?
